Drum to disc brake swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2012, 11:00 AM
when swapping the stock drums with a stock disc rear end do I need to use a different per portion valve in a 1991 s10 with a 350 400 turbo
Old 08-02-2012, 10:15 AM
Yes I would suggest finding one off of a camaro,or firebird 84-2000 with 4-wheel disk they are plentiful and are the simple to adapt to your application and are also close to the weight of your app.
Old 08-02-2012, 10:18 AM
that is unless you can get the one off the vehical the rear came from
Old 08-02-2012, 01:08 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You will need an adjustable proportioning valve as the factory valves will not have the correct bias front to rear..The do a et up routine on gravel until you get equal braking effort front to rear..
Sam
Old 08-20-2012, 09:01 AM
I got my rearend in and my timing adjusted and everything seems to be fine without changing my perportioning valve just though I would let u guys know
GM drum to disc swap dundirtcheap Suspension - Brakes - Steering 5 07-30-2012 08:40 AM
Disc/drum brake set up... Hwyhogg Suspension - Brakes - Steering 15 04-11-2011 09:57 PM
Drum/Disc Brake Proportioning Valve Help leejoy Suspension - Brakes - Steering 2 03-22-2010 09:59 AM
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 09:38 AM
drum to disc swap runn141 Suspension - Brakes - Steering 3 11-08-2006 09:19 PM
