Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drum to disc brakes
Old 03-11-2013, 07:17 AM
Bryan59EC's Avatar
Bryan59EC Bryan59EC is offline
Car? Truck? Who Cares
Last journal entry: First week of December
They will probably fit just fine.
Only issue may be where the brake hose connects to the hard line
drum brakes and Disck brake cars of the era used a different bracket
Some of these kits are kind of pricey
Might be a bit cheaper to acquire the pieces
a bit at a time and go from there.
I used components for a 72 Chevelle on my 66 Elky
Virtually everything you need will be available thru
any local parts store.
(be advised that doing this pushes the front wheels out 9/16" -- even the factory cars had a wider front track) this can be an issue with 15 inch wheels. I have 15x7 on 205-70-15 and get a fender hit on hard turns, stock height.
About all you would need to order would be the brake line kit, and disc brake spindles.
On a 67, your existing hard lines would be okay
the prop valve should work just fine-----I have a 67 valve in my 66 with no issues.
A disc/drum master cylinder will need to sourced and it is good to know that manual brake and power brake master cylinders are different
If going power brakes----and you already have power brakes, your hard lines should work
If you do not have power brakes and are installing power brakes----buy new hard lines for at least the front.
And think a bit ahead-----the right front line is different on a small block car vs a big block car.
If you have any notion at all about putting a big block in your 67----get the brake lines for a big block and stick them in. They are routed differently to not come too close tot he exhaust manifolds on the BBC.
Rotors
Calipers
Bearings
Master cylinder I used a 72 with power.
Booster
brake hoses
All available locally
Disc Brake spindles thru OPGI or virtually any other Chevelle Vendor
Disc brake hose brackets---again--OPGI
But---for a get-it-done-this-weekend job---a complete kit is the way to go
