Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drum to disc brakes
Old 03-13-2013, 09:01 AM
fwinter01 fwinter01 is offline
portion valve and reservoirs
Using a empie reservoirs mounted to the firewall, portioning valve down on the frame for line routing, would be ok to mount the 2lb check valve after the portioning valve leading to the front disc? Must be loosing disc line pressure over time from setting, portioning valve shuttles to lock out front disc
