drum to disc conversion? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2008, 07:51 PM
i have a 1970 nova i want to change to disc brakes in the front. do i need to change my master cylinder and proportioning valve to? not power brakes.
Old 05-26-2008, 08:10 AM
Yes. First, a drum/drum system doesn't even have a proportioning valve. Second, the master cylinder is very different between drum and disc systems. You probably should learn a little more about this before attempting it, for your own safety. The good news is that your 70 Nova uses the same brakes and spindles as a 67-69 Camaro, so parts and kits should be very easy to find.
Old 05-26-2008, 10:40 AM
Wiki Edits: 31
you don't really need to change the master cylinder. just insert a sheet metal screw into the center of the port for the front resivore, pull it out with a pair of pliers, that removes the 10# built in RPV, the only thing keeping you from using the drum brake M/C
Old 05-26-2008, 10:54 AM
conversion
is that where the line hooks up to or iside the bowls themselves? thanks
Old 05-26-2008, 11:11 AM
brakes
there is a bolt in the first resivour? do you mean that?
Old 05-26-2008, 02:43 PM
Wiki Edits: 31
if you look at the port where your front brake line hooks into, you will see a peice of rubber and in the center there is a small brass ring. insert the sheet metal screw in that and pull it out, it will take the rubber and brass ring with it. that stuff ls the built in 10# RPV ( requiered on drum brakes ). it will work with discs after you remove it.
Old 05-26-2008, 06:08 PM
brakes
ahh gotcha now! thanks.
Old 05-26-2008, 11:01 PM
'68-'74 Nova (and clone) parts will also work. '69 & later uses the single-piston caliper design, earlier uses the 4-piston units. The single is less prone to leakage and is easier to find parts for.
Your current steering arms will work, but if you find a set that are shorter, they'll give you quicker steering. Do NOT use Chevelle steering arms, they will screw up your steering geometry. Chevelle (and clone) spindles ('68-'72) will work, though.
http://nnnova.com/article_info.php?articles_id=13 is the National Nova Club's disc brake section. They used to machine drum-brake spindles to disc-brake specs, but I don't know if they still do.
Old 05-26-2008, 11:37 PM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
I used a '72 parts car (thats when you could still find parts cars) for the change over on my '71 and changed everything including spindles, calipers, hubs, brake lines and master cyl, then found the brake lines were different, and they didn't line up to the rear wheels cylinders. So I changed the rear end and the multi-leaf springs. Everything is different between the drum brake car and the disc brake option on a stock vehicle. The rear wheel pistons are also a different size.
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 10:06 PM
1971 Nova rear drum to disc conversion. 1971 Nova Suspension - Brakes - Steering 5 12-12-2006 04:07 PM
69 Camaro Drum To Disc Conversion kellycat Suspension - Brakes - Steering 3 01-16-2006 02:18 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
55 chevy bel air drum to disc conversion tk6002 Suspension - Brakes - Steering 1 11-25-2002 10:56 PM
