drum to disc conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2009, 08:41 AM
I have a 50 plymouth and am looking for a list of parts to pick off other cars to do this change on a budget i under stand a front end snub or front chaisse converision is better but i am laid off like everyone in the auto buissnes so i have to do this on a budget to still have fun with my family at local cruise nites thanxs jeff
Old 05-17-2009, 09:57 AM
powerrodsmike's Avatar
Wiki Edits: 161
Well I can almost guarantee that you won't find stuff that will bolt on in a junkyard, but there is a company that sells the minimum of custom parts you might need to do the conversion, and you can build the rest from junkyard parts or auto store parts.
check em out..I'm not sure they have your application, but they are worth a shot..
http://www.scarebird.com/
Later, mikey
BE different....ACT normal.
Old 06-14-2009, 09:02 PM
maybe you could go to pick a part and buy a front sub and make it work on your car maybe get a new hemi to put in it also???? that would be cool..
Old 06-15-2009, 05:13 PM
48ChryslerRodder's Avatar
Stuck in the past.
Try these links,
http://pwhm.orvf.com/jim_wilson_ncputzer.htm
http://www430.pair.com/p15d24/mopar_...ighlight=smith
http://www.merc583.addr.com/mopar/p15pages/links.html
http://home.roadrunner.com/~dndrodshop/disc.htm
The second to last link I posted has many different links that may help. If you can locate the Tex Smith how to book it may help.
Last edited by 48ChryslerRodder; 06-15-2009 at 05:21 PM. Reason: found good link to add
Old 06-16-2009, 06:23 AM
mopar brakes
I have seen the tex smith article on adapting disks to mopar spindles on line-
google it and you can find it. As I recall it used rear rotors from a Toranado adapted to stock hubs. Good luck Jim
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 09:06 PM
69 Camaro Drum To Disc Conversion kellycat Suspension - Brakes - Steering 3 01-16-2006 01:18 AM
drum to disc conversion. 409guy Suspension - Brakes - Steering 8 09-05-2005 08:03 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
55 chevy bel air drum to disc conversion tk6002 Suspension - Brakes - Steering 1 11-25-2002 09:56 PM
