drum to disc conversion kits - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2005, 11:15 AM
New Member
i was maily looking for a 63 impala drum to disc conversion kit when i came across this page
disc brake conversion kits
View Part
58CBK-S
5964CBK-S
5864CBK-D
Description
1958 Chevy Stock height conversion - No new Spindle
1959-64 Chevy Stock height conversion - No new Spindle
1958-64 Chevy 2" Drop conversion - New Drop Spindle
Upgrades
Cross Drilled & slotted Rotors
4 wheel disc prop valve
Stainless braided front brake hoses
Disc brake conversion brake line set - OEM Tin Coated
Disc brake conversion brake line set - Stainless Steel
Conversion brake Line clip set
For pieces of the kit - upper or lower kits - click here!
Stock Spindle Disc Brake Kit - This kit retains the stock height of the car using the original spindle. The kit moves the front wheels out 3/8" on each side and works with most 15" wheels.
Drop Spindle Disc Brake Kit - This kit drops stock height of the car 2" using a drop spindle. The kit moves the front wheels out 1/8" on each side and works with most 15" wheels.
Complete Kit Includes (All New Parts): Disc Brake Caliper Bracket Kit, Rotors, Calipers, Pads, 9" Smooth Face Booster, Master Cylinder, Disc Drum Valve, Valve Bracket, Master to Valve Lines, Brake Hoses, Bearings, Seals, Banjo Bolts, Crush Washers, all Misc. Hardware and installation instructions. Drop Kits also include the drop spindle.
1958-64 Cars came with a single master cylinder that feed the drum brake system. The power disc brake system upgrades to a dual master cylinder and proportional valve. This allows the brake fluid system to be separate decreasing total system failure if one line is compromised. If your stock Chevy is in need of disc brakes this is the setup for you. Also offered is a 2" drop spindle kit. This kit lowers the car using a drop spindle. When upgrading to disc brake the car should be upgraded to 3/16 brake line, this size line build up more pressure and gives a much better pedal feel. 3/16" line is commonly used for disc brakes while 1/4" line is used on full drum brake cars
Old 09-05-2005, 03:31 PM
1972_El Cameno's Avatar
New Member
Last journal entry: 1972 Chevy El Camino. for sale
drum to disk brake's
hi hopfally you can answer my ? I got a 1972 Chevy El Cameno and i wount to put power steering and put disk brakes on it do you know off of what car/ truck i could take it off of that it would work off of or if you dont if you can give me some info on how to find out the answer to my ? thenk you dan
Old 09-05-2005, 05:28 PM
1Fast65Elky's Avatar
Left Nut, Right Nut....Squish!
72 el,
theres plenty of threads with the answers your lookin for, do a search.
I would tell ya but i cant seem to find my notes right now...Most of the cars in the link above will interchange (the gm a-bodys) gto, 442, monte carlo, chevelle, elcamino, 64-72 years or somethin like that.....The search will return good results, you should do the search you wont be dissapointed.
Old 09-05-2005, 08:36 PM
New Member
hi hopefully you can answer my ? I got a 1972 Chevy El Cameno and i won't to put power steering and switch from drum to disk brakes on it do you know off of what car/ truck i could take it off of that it would work off of or if you don't if you can give me some info on how to find out the answer to my ? thank you dan
ps: i was wondering if any one know's if theres like a way i could go to a junk yard and grab it off of a car/truck and it would work and if so what kind of car year/make model
Old 06-06-2007, 09:06 PM
aahhhh!! this is the thread i'm looking for. ok, dmented/ 1fast65elky, what vehicle makes or models will be a good steering and disc brake swap for a 67 chevy pick up? this truck is built for street/strip, but, may see some river with the boat. 383 th350 w/3.73 rears.
thanks
chevy 3/4 ton rear drum to disc conversion Rob Keller Suspension - Brakes - Steering 33 12-03-2005 04:59 PM
drum to disc conversion. 409guy Suspension - Brakes - Steering 8 09-05-2005 08:03 PM
drum to disc conversion astrops Suspension - Brakes - Steering 3 04-08-2004 04:55 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
55 chevy bel air drum to disc conversion tk6002 Suspension - Brakes - Steering 1 11-25-2002 09:56 PM
