drum to disc swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2006, 12:34 PM
runn141's Avatar
SB S10
drum to disc swap
i have a 87 s10 with drum brake rearend. i purchased a rear disc brake rearend from a 2000 s10 blazer 2 wheel drive. is it gonna need more than just bolting it in and hooking up lines or am i going to have to have a special type proportioning valve or something else for it to work properly?
Old 11-08-2006, 12:50 PM
biggeazy-e's Avatar
i havent done the swap, but a friend of mine did a drum to disc rear on an elcamino, he says he needed a new prop. valve..
Old 11-08-2006, 07:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
moving to suspension & brakes forum.
Old 11-08-2006, 10:19 PM
techinspector1's Avatar
Wiki Edits: 326
I'd be wondering if the master cylinder has enough volume to fill the rear caliper (calipers usually need more volume than wheel cylinders, right?). I'm not sure in the case of the S10, just trying to help you cover all the bases.
GM drum to disc swap dundirtcheap Suspension - Brakes - Steering 5 07-30-2012 09:40 AM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 10:06 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 10:00 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
