Drums on Big Block Chevy Luv - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2011, 10:49 PM
31fordcoupe's Avatar
Last journal entry: Gunked up 454 water jacket
Hello gents,
Got a quick question regarding drum brakes on my truck. It is a 72 Chevy Luv that just received a moderately built 454. Within the next twelve months this moderately built 454 will start its transformation into a 454 that will have forced induction by the way of two Holset HX35w turbos.
I currently have the stock 6 lug drum brakes on the front and a Dana 44 under the rear which also has drum brakes.
At the end of the race season this year the Dana 44 is going away and will be replaced by a narrowed 9 inch that will have disc brakes. My question to you all is, in general, how much more "braking power" will I get by going to discs in the rear and discs up front over my current set up?
I currently have a Wildwood dual reservior 7/8" master cylinder, with no booster and an adjustable brake pedal that allows me to adjust the amount of pressure between the front and rear brakes.
I really don't have room for a brake booster in my engine compartment at this point (without alot of modifications) so I would like to use the same dual resevoir master cylinder with the Ford discs in the back and drum OR discs up front. I can go to a brake booster with the drums if absolutely necessary, but I will have to do a decent amount of modification to the front fender supports (at least on the drivers side).
The only front disc brake kit I have found for the Chevy Luv has been on Ebay and they want $880 for it. Here is the link:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
This kit would also allow me to lose the 6 lug set up that is on there now and go to a Chevy or Ford bolt pattern so that is an added bonus. I just want to know if the $880 disc set up will provide me with additional "braking power" over my current set up, and if you guys think that it would be worth the expense.
The truck weighs about 2800# and with all drums on it now, the rate at which it decelerates once the brakes are applied is leaving something to be desired.
Any suggestions you have will be greatly appreacited. Just trying to get the most brake, without breaking the bank.
Old 01-30-2011, 11:02 PM
ericnova72's Avatar
More for Less Racer
Disc brakes up front will be a huge improvement, you won't believe how much better it will be. If you don't want to disc the rear the big 11" rear Ford drum brakes do just as good a job for less $$$, just weigh more than rear disc's.
All a vacuum brake booster does is decrease the amount of pedal pressure needed from the driver...it doesn't increase braking power at all. It is just a convenience item for lazy drivers and old folks.
Old 01-31-2011, 02:36 AM
SSedan64's Avatar
I have a 76 Luv w/SBC400. It has factory Power Disc/Drum, the Booster is tiny but, it stops "very" well. I believe it would stop fine with Manual Disc/Drum. You could use cheap factory Disc from a Luv or Isuzu Pickup. I'm not sure which years will interchange, probably a Luv Forum somewhere w/Info.
I'm using a set of factory 15" Aluminum rims from a Toyota 4X4, they fit perfect. 205/60/15" Front & 255/70/15" Rear tires.
If you're set on dumping the 6 lug pattern all this Info is no good tho'.
Mine has Manual steering and it's very easy to steer, twice as easy as the 86 & 87 Toyota trucks I have w/4cyl. engines.
A little Brake, Parts/Yr. Info:
76-80 Luv= Disc/Drum
80-83 Isuzu Disc/Drum
84-87 Isuzu Disc/Drum, w/Vented Rotors
Old 01-31-2011, 08:44 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Hey, hey! Come on Eric , easy on us old guys!
Old 01-31-2011, 09:08 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The thread HERE talks about using S-10 spindles etc. to get 5-lug disc brakes on the front of a LUV. About half way down the page, the member "da LUV masta" lol offers up drawings (for a price ) to do the swap yourself. Might be worth a look, as well as the rest of the site under Board index Technical Body and Chassis Upgrades.
OT- A buddy of mine had a LUV, way early like yours w/the 4-cylinder engine. Talk about slow- but it got hellacious mileage!
Old 01-31-2011, 03:32 PM
Thanks much to all of you for your responses. EricNova72, as usual, you are spot on.
Cobalt,
The guy you are referring to as "da LUV masta" is a guy that lives in my town and I am aware of his conversion kit. I have spoken to this guy on another website and we got into a discussion about the differences in weight between a SBC and BBC and that it was a waste of time to put a BBC into a Chevy Luv because of traction issues. As silly as it seems, it degraded into a pissing contest.....so we are now gonna race heads up this summer in El Paso. His blown Buick V6 vs. my big block. I will probably end up getting my butt handed to me since my build is relatively mild as far as big block builds go, but at the end of the race season, I will start the transformation to the dual Holset HX35 set up with the 4 link, 9 inch etc., coil overs, air to water IC, etc. and then we can rerun it. I can GUARANTEE I won't lose that race.
I'm not gonna bad mouth the guy here. I am sure he is doing a good job of it, but......that Aerospace kit will do the job and they have cool stuff that go along with their brakes like "product liability insurance" and "warranties" and "quality control". That's all I have to say about that.
This is my second Luv, and you are right, the stock 4 banger took a week and a half to get to 4th gear. And as you have also stated, it was reeeaalll good on gas. But I think I'm done with slow Luvs, I want the fast ones.
As usual, all of you are a class act and I appreciate your insight and the sharing of your knowledge.
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 07:36 PM
58 chevy truck swap drums for disc 58chevy Suspension - Brakes - Steering 1 11-29-2010 09:15 PM
1937 chevy coupe rear brake drums a70dart Suspension - Brakes - Steering 2 05-04-2010 08:16 PM
65 Chevy P/U Drums to Disc brake change dar130 Suspension - Brakes - Steering 11 04-20-2008 10:01 AM
I need help with my breaks,swap drums to discs 1974 chevy nova lovethehotrods Suspension - Brakes - Steering 4 11-30-2006 08:12 PM
