Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drums Pontiac Bonneville 67
Old 08-19-2008, 11:05 AM
BonnevilleDriver.Be BonnevilleDriver.Be is offline
Originally Posted by joe_padavano
If you press out the wheel studs, you can separate the hub from the drum. You can also press the bearing races out of the hub if necessary to replace them. I'm sorry, but you post wasn't terribly clear.
yeach srry that the post was not so clearly,but to typ and know all the technical words .... im from belgium so its difficult to explain
thx
