Drums Pontiac Bonneville 67 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2008, 10:56 AM
Hi,
I have some problems with my front drums, There where my wheel bearrers are is broken, i can move the outer ring of the wheel bearrer to te left and right it isnt stuck, like it supost to be.
So i've tried to find me a new mid cilinder or drum but the problem is my bolts to attach the wheel and the midcilinder is out of one piece and on the internet i cant find a mid cilinder or the bolts, even the same drum with the bolts and cilinder out of one piece
i went to an all american cars and parts store but they coudent find it ether so what should i do....?
Does somoene know where i can find these drums
Or ive been thinking to replace the front drums by disc brakes... can i do that without any dramatic changes ....?
here are some pics
grtzz
Old 08-16-2008, 01:10 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
It is hard to tell from the pic's, but it looks like the wheel bearing races are ok. Do you know if it is just the wheel bearings that you need?
If the hub needs replaced, I believe they need to be pressed out of the drum and a new one pressed in. The bearings and races are available as is the drum. Not sure about the hub.
Check for all parts except the hub Here
This is one way to put disc's on it.
http://www.scarebird.com/12802/21632.html
Old 08-17-2008, 03:58 PM
If you press out the wheel studs, you can separate the hub from the drum. You can also press the bearing races out of the hub if necessary to replace them. I'm sorry, but you post wasn't terribly clear.
Old 08-17-2008, 08:49 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
It 'appears' that he needs replacement hubs.
67/8 big pontiacs should be the same, as they are essentially the same car.
Some other GM cars may use the same hub as well.
Be careful----there may be a hub change between the the Bonneville and the rest of the lineup.
Same may be true for the other GM models.
Old 08-19-2008, 11:02 AM
thx 4 the info ...
but ive found a company thats speciliased in brakes and bearrings,
and they found the drums i need hub and bolts in one ...
and its the same drum of GTO
It was so difficult to find cause there are just a 400 with this system, so ....
But they looked it up with my chassis number...
So lets hope ... ^^
thx all
Old 08-19-2008, 11:05 AM
yeach srry that the post was not so clearly,but to typ and know all the technical words .... im from belgium so its difficult to explain
thx
67 Bonneville.....HELP marcosgarage Suspension - Brakes - Steering 15 03-15-2008 01:04 AM
Hello Everyone....1967 Pontiac Bonneville marcosgarage Introduce Yourself 2 01-26-2008 12:30 PM
Some simple questions ref. my 67 Pontiac tk421 General Rodding Tech 2 12-21-2007 08:14 AM
67 bonneville interior champ Interior 1 01-28-2006 07:23 PM
