Dry sump - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2013, 11:33 PM
Racer Rex's Avatar
Hoper and Dreamer
Dry sump
If you had all the parts (and I do), would you run a dry sump oiling system on your street rod? Why or why not?
Old 05-27-2013, 11:43 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I run dry sump on our Sprint Cars and if you ask me, that is the ultimate oiling system for any engine, street or race.
PROS:
1. The dry sump is not as picky about overfilling the reservoir like a wet sump pan system.
2. You can easily adjust the oil pressure to taylor it to the system.
3. The oil stays cooler because it is circulated back to the external reservoir instead of staying in the motor where all the heat is.
4. All parts are external which makes for easy repairs.
There are a few more pros to a dry sump but to me these are the top three.
CONS:
1. Cost more to install
Old 05-27-2013, 11:50 PM
Racer Rex's Avatar
Hoper and Dreamer
I have the parts left over from my asphalt late model that I'm thinking of putting to use when I start building my motor for my car. The 406 I have is already drilled and tapped as it was once dry sumped. But I'm getting the vibe, from another post, that I may not want to use the block I have. But drilling and tapping isn't a huge project. Thanks for your response.
dry sump help fulltruckereffect Engine 3 10-02-2006 05:57 PM
Dry Sump alex_0227 Engine 3 04-05-2005 10:22 PM
Dry Sump Oiling System bonuts Engine 29 01-02-2005 10:41 AM
more on the dry sump jway83 Hotrodders' Lounge 1 08-08-2004 09:12 AM
dry sump system jway83 Hotrodders' Lounge 3 08-07-2004 09:03 PM
