Drying times for taping on Base coat. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2011, 02:44 PM
I need some information on the time required to tape on base coat. Is it required for the paint to be completely dry, or is there some time that taping can be done before that. I am trying to do a stripe on the hood, using a different color and need to tape it off first. I have sprayed the base coat for the first color already. I want to spray the second color, and then clear the entire hood.Thanks for all the help.
Last edited by retiredusncustoms; 09-04-2011 at 03:12 PM. Reason: More explanation
Old 09-04-2011, 03:35 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I want it to be dry..you can check by putting a piece of tape in the area to shot and see if it lifts the base..if it does wait a while longer..
Sam
Old 09-04-2011, 06:43 PM
Thank you Sam. I done just about that a little while ago and lucked out, as it did not pull the base coat. I went ahead and painted the other base, then the clear. Worked out okay. A little wet sanding, buffing, should be good for a driver. Thanks again. K.C.
Help with PPG Deltron base coat paint and clear coat Please smithkustoms Body - Exterior 31 01-12-2012 08:43 AM
Base coat/clear coat urethane over acrylic enamel mervhudson Body - Exterior 5 04-23-2011 11:56 AM
drying times for reducers xpsyclonex2002 Body - Exterior 6 05-03-2010 08:04 AM
base coat paint and base concentrate questions student blake Body - Exterior 13 08-02-2006 11:33 PM
laquer primer/ppg base coat/clear coat? dave mc Body - Exterior 5 10-11-2005 05:59 AM
