dtc's on obd2 Need help understanding. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2008, 05:13 PM
I have just finished a 37 ford fiberglass street rod with a 6 liter engine and automatic trans.out of a 06 GTO 6000 miles. The wiring harness is from street and performance. The computer has also been reworked by them. My question is, I have a check engine light on and after scanning the trouble codes one being po174 system to lean. (Possible fuel injector restriction ) The second code po690 has me stumped ecm/pcm power relay, sense circuit Hi. If anyone can shed some light on this I would appreciate the feed back.
Old 04-21-2008, 09:41 PM
sharpe427's Avatar
The lean code would more than likely be a vacuum leak somewhere. The 690 code is sensing the voltage input to the ECM power circuit is too high...make sure that the oe GTO circuit did not reduce input to the ecm (not run 13.8-14.1V straight off the alternator). An understanding garage or friend would be able to get you a spec sheet and wiring diagram.
Old 04-21-2008, 10:41 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
p0690 is set when the ecm detects voltage with the switch is off, this being from the relay feedback circuit(pin 86 if I remember). The brown wire at the relay is the wire the computer commands off. Check it for power with the key off.
Old 04-23-2008, 02:39 PM
This aftermarket wiring harness comes with a 8 panel fuse block and has two relays to my knowledge. One for the electrical fuel pump and the other is a starter relay. I also ,wanted to mention this also has a ez wire fuse panel. Thanks for your help.
Old 04-23-2008, 04:12 PM
Update on dtc690, spoke to the programmer about this and he states that the original wiring harness had a relay, however, they just turn this circuit off when they reprogram the computer for there harness. He states this won't cause any problems to the computer.
Understanding Torque converters Warrant Hotrodding Basics 5 08-09-2006 01:17 PM
Major advance in understanding the programming of life.... JunkYardFrog Hotrodders' Lounge 5 05-05-2005 01:47 PM
Talk about an understanding wife Bluepen Hotrodders' Lounge 15 04-12-2004 02:56 PM
I have a VERY understanding wife - Part II Centerline Hotrodders' Lounge 7 04-07-2004 12:52 PM
Understanding Engineers 406chevelle Hotrodders' Lounge 10 03-16-2004 10:43 AM
