Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - DTM primer questions
Old 12-26-2012, 12:59 PM
mr4speed mr4speed is offline
First off nothing sticks like epoxy (spray glue) and as deadbodyman says you can use this particular epoxy (SPI) all the way through start to finish (sealer). One of the latest cars I just did I did use this epoxy as a finish primer over a spray poly instead of the 2K urethane and was quite happy with it, it does block out pretty good. And the savings are quite high as one two gallon setup should be able to do a whole car start to finish.
