Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - DTM primer questions
  #37 (permalink)
Old 12-31-2012, 02:07 PM
mitmaks's Avatar
mitmaks mitmaks is offline
Last journal entry: Grille
Originally Posted by deadbodyman View Post
I do it all the time I hardly ever use a sealer (even epoxy ) Only on high end super straight work do I use an epoxy sealer when I do seal I always sand it before paint.
If youve ever sanded an after market panel(like a hood )you;ll sand the primer off in many spots (I usually sand all that cheap primer completely off)or if you strip a panel and it dosent need any filler work you can reduce the SPI to 20-40% and after spraying two coats go right to paint,it flashes pretty fast.
Why do you sand sealer? To reduce orange peel or???
