-   -   Dual A/C (http://www.hotrodders.com/forum/dual-c-208251.html)
sawzall 11-06-2011 12:11 PM
Dual A/C
in December of 2009 I managed to find a vintage air setup for my 1940 ford.
woodie air
unfortunately the under dash area of a 40 wagon is somewhat limiting.. especially when your buying someone elses used parts!
http://images46.fotki.com/v1395/phot...SC00303-vi.jpg
to compensate I am thinking about installing a second evaporator for rear seat passengers..
http://4.bp.blogspot.com/-Z_Icey2PAo.../dadsphoto.JPG
I have two concerns..
1. what does the A/C line routing look like (ie do I put the second evaporator in series with the first, or parallel?)
2. how do I determine what size compressor I need?
LATECH 11-06-2011 12:30 PM
The second evap should be parallel with the first.
Your compressor (if healthy) will be fine , it will keep up.
Most systems use an orifice tube for the front and an expansion valve in the rear.It is a little easier to fill/diagnose a system with that combo as the orifice is a constant and the expansion valve is a regulatory type device.
If the front has an expansion you could run the orifice in the rear, but the rear may cool better/ faster untill the system gets stabilized after a few minutes of run time.
You can run expansion valves on both ends if you like ,but it will be a little trickier to arrive at the correct pressures / charge amount as it would take a little more time for the temp/ pressures of the system to stabilize.
Super Nifty Woody BTW. :thumbup:
sawzall 05-01-2012 07:59 PM
thanks.. I started the install and appreciate the info!
jon72vega 05-05-2012 09:05 AM
Nice Woody!
Jon
http://1972vega.wordpress.com/
DoubleVision 05-06-2012 12:47 PM
I bought a 34 wagon and we call it a woody
Surf city here we come...
