Dual A/C - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2011, 12:11 PM
Dual A/C
in December of 2009 I managed to find a vintage air setup for my 1940 ford.
woodie air
unfortunately the under dash area of a 40 wagon is somewhat limiting.. especially when your buying someone elses used parts!
to compensate I am thinking about installing a second evaporator for rear seat passengers..
I have two concerns..
1. what does the A/C line routing look like (ie do I put the second evaporator in series with the first, or parallel?)
2. how do I determine what size compressor I need?
Old 11-06-2011, 12:30 PM
LATECH's Avatar
Last journal entry: New Gas Tank
The second evap should be parallel with the first.
Your compressor (if healthy) will be fine , it will keep up.
Most systems use an orifice tube for the front and an expansion valve in the rear.It is a little easier to fill/diagnose a system with that combo as the orifice is a constant and the expansion valve is a regulatory type device.
If the front has an expansion you could run the orifice in the rear, but the rear may cool better/ faster untill the system gets stabilized after a few minutes of run time.
You can run expansion valves on both ends if you like ,but it will be a little trickier to arrive at the correct pressures / charge amount as it would take a little more time for the temp/ pressures of the system to stabilize.
Super Nifty Woody BTW.
Old 05-01-2012, 07:59 PM
thanks.. I started the install and appreciate the info!
Old 05-05-2012, 09:05 AM
jon72vega's Avatar
WOW, I could have had a V8!
Nice Woody!
Jon
http://1972vega.wordpress.com/
Old 05-06-2012, 12:47 PM
DoubleVision's Avatar
I bought a 34 wagon and we call it a woody
Surf city here we come...
Blazer dual piston setup Vs. SSBC dual piston calipers! veltboy314 Suspension - Brakes - Steering 1 11-28-2010 06:37 AM
454 tbi or dual tbi on dual 4bbl carb intake 90GMCVortec Engine 3 10-28-2008 02:48 AM
dual carb 86regal Hotrodding Basics 3 03-11-2008 07:34 PM
Best dual 4's for our 428? Ripped Engine 6 07-16-2005 12:35 PM
dual 4's on 390 65galaxie500 Engine 4 06-21-2003 01:33 PM
