dual carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2008, 07:15 PM
dual carb
whats the best set up for a dual carb set up for a Chevy 350?
what would be the best advantages/disadvantages for each set up?
what would be the power gain over a stock intake/carb?
Old 03-11-2008, 07:30 PM
life is a temporary assignment
I ran two 450's on a tunnel ram on my 350.I had two 600's,But ran alot better with the 450's.That's 900 cfm's,You would usually run 600 to 750 cfm's On a single carb motor.My 350 was a 11:1 motor.If I was to run another tunnel ram,I will go with the 450's again. If you want max performance,Go with one carb.
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
There are many threads on this subject. Try doing a search and see if you find the info you are looking for that way. If not, please give us some more specific info on your combination.
Old 03-11-2008, 07:34 PM
i did look up dual carbs but didnt find anything useful to me
the motor has flowtech headers and a lunati voodoo cam(forgot the specs)
other then that the motor is stock
its in a car that i just bought(1990 trans am)
600 v. 750 carb on my 350. Help me out! Porschev Engine 11 11-22-2007 02:58 PM
Too much carb? KNanthrup Engine 5 09-03-2005 06:47 PM
25 Year-old Carb, rebuild or trash? Arcuden Engine 6 07-31-2005 08:42 PM
Need help with Edelbrock carb Crazy-J Engine 1 06-01-2005 02:24 PM
Single plane and duel plane manifold stonedchihuahua Engine 21 01-06-2003 11:56 PM
