Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 06-26-2006, 06:37 PM
smallblock450sl smallblock450sl is offline
dual exhaust question
I'm going to install a dual exhaust on my mercedes 450 sl . The car has a sbc 350 vortec and a 700r tranny. I'm going to stick with stock cast iron exhaust manifolds. The problem is clearance/space for 2 mufflers. Was wondering if anyone has heard of a 2 inlet and 2 exit style muffler. Thought late model Vettes had them, but contacted "Borla" and they don't handle one. Thanks for the help.
Old 06-26-2006, 09:21 PM
chevy302dz chevy302dz is offline
re: dual exhaust question
I think the first gen Camaro's may have had a setup like that, maybe someone else here can confirm?
Old 06-27-2006, 09:16 PM
jimfulco jimfulco is online now
Dynomax #17725 is a dual-in/dual-out muffler with 2-1/4" inlets & outlets. It's the one that's used for early Camaros & Novas with factory dual exhaust. In normal configuration, with inlets directly across from each other, they are pretty restrictive, and only capable of supporting 237hp, according to Dynomax. They will, however, flow straight through, with inlet pipes offset on either side, or with both inlets on one side.
My Nova came with that type of muffler, and you can look down each inlet/outlet and see all the way through out the other side, and the inner flow tubes are perforated just like a good glasspack. I suspect the Dynomax is constructed similarly, but I don't know for sure. If so, it should support quite a bit more power if the exhaust runs straight through, but I suspect it'd be quite a bit louder.
Flowmaster also makes a muffler with a similar external configuration, and the one I heard (on a Firebird 400) was LOUD.
Fine print says "will flow all directions/connections"
Old 06-28-2006, 05:47 PM
Thanks for the input guy's.........I'll look into both sources mentioned. Would like a "small block" "rumble" tone, but don't want to be to loud outside or inside. Thanks
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "dual exhaust question"
Can I make my 200ci 68 mustang have dual Exhaust my68stang Engine 21 11-14-2007 06:43 PM
New Exhaust and now the engine runs hotter... nsane Engine 4 10-16-2005 02:30 AM
6 cyl 68 stang, should I make it dual exhaust my68stang Engine 10 09-21-2005 07:54 PM
Exhaust question.... Mister4.6 Engine 0 10-14-2003 12:59 PM
another exhaust question chevyman17 Hotrodders' Lounge 0 03-14-2003 10:18 AM
