Dual M/C for '55 Ford & Residual Valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2008, 06:27 PM
Sweet-34's Avatar
Lost In The 50's
Just purchased a Power Brake kit from MBM Brake for my '55 Ford Customline with 4-wheel drum brakes.
It has a 7" Dual Diaphragm, 1" Bore Corvette Style M/C (no built-in residual valve), firewall bracket and inside pedal linkage.
My question.....Do I have to install 10# residual valves in the front and back lines? The M/C is mounted high on the firewall far above the wheel cylinders. Remember now...this is an all drum car!!!
If I don't install the residual valves, what kind of pedal feel am I going to get? Or will I feel a difference at all?
Mfg. recommends residual valves!!!!!
Thanks for all your input~
Old 07-14-2008, 06:54 PM
Will I ever get it done?
Last journal entry: Hood
Drum brakes need a 10# residual pressure valve. Wheel cylinders seal real well in one direction only. Without a small amount of pressure in the wheel cylinder, air can enter. The pedal may be great right after you bleed the brakes, but you will eventually get more and more air and the pedal will get spongy.
Old 07-17-2008, 04:25 PM
Sweet-34's Avatar
Lost In The 50's
Installing Residual Valves
After much discussion on other forums, I've decided to install residual valves in front and rear lines. I'm replacing all the lines anyway and it's not going to be much more work to put in the residuals.
Thanks for your reply
Old 07-17-2008, 09:00 PM
56 Ford Custom
Sweet, I have a 1956 ford customline I am working on. Thought maybe we could swap info and how to's. Shoot me a pm or let me know how to get in touch if you want to.
Todd
Old 07-17-2008, 09:12 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
I used them on my 56 F-100 (drum brakes). I was told you needed them regardless, but my power brake booster and dual resivour master cylinder are mounted under the cab.
I also have vacuum wipers. The old Y-block does not have enough vacuum for it all. I installed a vacuum canister under there as well from Summit racing. Fixed it right up.
Old 07-18-2008, 06:46 AM
Sweet-34's Avatar
Lost In The 50's
This one's for you TODD!!!
Todd: I've added you to my buddy list and will send you a PM. Thanks~~~~Ron
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
Henry Ford in Heaven schnitz Hotrodders' Lounge 9 10-19-2004 10:09 AM
Dual M/C which bowl for disc and drum?? Ed ke6bnl Suspension - Brakes - Steering 4 09-15-2003 06:59 AM
How do I install dual side pipes on on 97' Ford Ranger? John Rose Engine 2 01-15-2003 05:38 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
