Mike,
I can't help you as far as pedal effort (yet), but here's a pic of the mockup in my '47 Ford coupe. This is a Wilwood 340-5181 dual M/C reverse-swing pedal assembly with 6.25:1 ratio. I'll be using a 7/8" bore up front and a 1 1/8" bore for the rear because (due to my ignorance) I used front calipers for both front (2 1/8" piston) and rear (1 5/8" piston) systems. There is another option for under dash that can use a power booster, Kugel's 90 degree mount unit, but it uses only a single M/C. Russ |
re: Dual Master Cylinder Brake Pedal with Balance Bar
Russ
I would be interested to know how it turns out. You are a little further along than me but where thinking along the same lines with Wilwood and Kugel except I was thinking about adapting a Dual Master Cylinder Brake setup based on Kugels 90 Deg. setup and Wilwoods 60 Degree Balance Pedal Assemblies. Mike Last edited by iceman36; 02-22-2006 at 03:20 PM. |
Dual masters are no different than a normal master pedal feel wise.
Properly designed a manual system will be just fine, but a manual disk system will always require some effort. They are usually designed for 100lbs of pedal pressure to get 1g of stopping force. keith |
we used a dual master unit like the one your talking about in a pretty nasty 26T we built at our shop, its got about 600++ hp willwood disc on all 4.
it got away from me one time and i had to slam the brakes, and it woulda stopped on a dime if it wasnt running 3" fronts and 15" rear meats! it came to a controllable stop/slide and all was safe! i dont like booster type braking systems because it robbs vaccume! and if you CAN run a booster, you dont have enough cam! that master will work just fine with the correct check & proportioning valves! Brian |
Thanks I have not taken any measurements yet or run any numbers.
But from what I can see the brake pedal will be longer than most setups which should give me more leverage. So if I run the numbers using what I do know and play around with different pedal ratio, piston sizes and travel. I should be able to chart some design setup then do some CAD drawings and run it by Willwood before I start fabricating and spending money, companies usually work with you when you’re spending a couple grand or more. I don’t think this 3000lb gorilla will ever get away from me like your 26T but slowing it down has to be on the top of my list or I could be on top of something else at the bottom of the hill. I have been out of the loop with doing the 9 to 5 and raising a family so any help is greatly appreciated. Thanks Mike |
C4 Corvette Brake Questions |
| Master cylinder to fit 8" dual booster | jcarter | Suspension - Brakes - Steering | 7 | 05-25-2006 01:13 AM |
| Master cylinder sizing, dumb question? | baddbob | Suspension - Brakes - Steering | 6 | 06-19-2005 01:02 PM |
| 1966 Chev PU upgrade to dual master cylinder for existing brakes | Bannear | Suspension - Brakes - Steering | 7 | 10-23-2002 01:15 PM |
| need help finding dual master cylinder | WayOutCat | Suspension - Brakes - Steering | 6 | 08-16-2002 11:51 AM |
| Stang master cylinder | Old Crow | Suspension - Brakes - Steering | 3 | 06-10-2002 12:40 PM |
