Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 03-27-2007, 10:09 PM
Rambo_The_Dog's Avatar
Rambo_The_Dog Rambo_The_Dog is offline
Dual Oil Filters - Worth it for Daily Driver?
The engine in question will be a mild 454 and will be used in a daily driver because of my exhaust clearance I need to run a remote oil filter and I'm wondering if its worth the expense, space, maintenance, xtra parts etc. to go with a dual filter setup or stay with a single remote filter.
What kind of oil lines have people run using a remote filter? I'd like to use something retro - copper maybe?
Thanks
Old 03-28-2007, 03:17 AM
Guy Hiltz's Avatar
Guy Hiltz Guy Hiltz is offline
Dual Oil Filters-Worth it for Daily Driver?
I've got a remote oil filter on my car but just use a single filter,theres no room for a double,but with a quality oil filter such as the K&N,theres probably no need for to use a double set up,just extra expense at oil change time.As far as lines,I use high pressure rubber with heat protection between the block and headers and also have a couple of home made brackets to keep the lines from hitting the headers.I also use wire loom in the engine compartment to protect the lines from sharp edges.
Old 03-28-2007, 09:24 AM
farna's Avatar
farna farna is offline
 farna's barnstar
re: Dual Oil Filters - Worth it for Daily Driver?
Go to www.amsoil.com and read up on their double filter. At least their system uses a standard filter then a filter that will clean the oil even better. It's made specifically for long drain intervals though. In fact, I don't think there is a drain interval with that type system -- you just replace the filters and top off every 5K or so miles and never drain the oil. That's possible for two reasons: synthetic oil is used and a "fine" fileter is also used. With EFI it's a no brainer, but they designed that system for carb and diesel engines... as far as I recall. Things change: look it up on their site!!
Old 03-28-2007, 11:40 AM
bondo bondo is offline
Ayuh,.........
I don't think it's even Possible to Over-Filter Oil..........
The More it's Filtered,... The Longer the motor will Last,.......Period........
Old 03-28-2007, 12:42 PM
Jmark's Avatar
Jmark Jmark is offline
HR moderator dude
There is a great oil web site that will give you tons of good reading on everything oil and filters,,,,,and even (cough cough,,,,K&N filters!).
www.bobistheoilguy.com
Give it a look. Great site.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Dual Oil Filters - Worth it for Daily Driver?"
remote oil filters fyritup Engine 4 04-12-2004 02:02 PM
Frantz oil filters Jmark Engine 11 04-09-2004 10:31 PM
Honeywell Oil Filters poncho62 Engine 3 03-18-2004 06:50 AM
Speaking of Fram oil Filters Rad Ray Engine 3 12-02-2003 08:12 PM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 05:17 AM
