dual pickup distributor for a dodge 440 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2012, 06:48 AM
dual pickup distributor for a 440 ?
who makes a dual pickup distributor for a 440, factory or aftermarket? if factory what was the applications they came in.
or if you have built your own could you give me info on parts you used to accomplish this.
Old 11-02-2012, 01:31 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
Depends on the year.
vicrod
Old 11-02-2012, 04:56 PM
LATECH's Avatar
Last journal entry: New Gas Tank
I remember seeing a dual pickup in a mopar back in the day. Just cant remember what it was in.
It may have been in one of the early lean burn systems in the early 80s.
One for start and one for run. IIRC it was not in a Big block though. The dizzy plate may interchange though. Just a thought.
Fact is stranger than Fiction
Old 11-02-2012, 05:11 PM
LATECH's Avatar
Chrysler stopped building 440 s in 78 IIRC. Seems they had an electronic ignition that had 2 pickup coils in it that was built for the 440.
Check in the salvage yard in the 1 ton trucks and old motorhomes.
I think the dual system had dual ballast resistor also.
Dodge 440-3/440 heads - RV vs.standard MopaRV Engine 2 08-02-2012 02:53 PM
440 dual quad waylon a Engine 1 10-15-2008 10:35 AM
dodge 440 cfs Engine 12 06-22-2008 07:43 AM
440 Dodge hd, hr. allstar mike Engine 3 05-31-2006 03:33 PM
440-3 vs 440 Dodge??? WoodsEdge Engine 4 11-14-2002 05:22 AM
