dual pot vaccum advance, where to connect? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2012, 12:30 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I have this points distribuitor installed in a Ford 300 inline six
it has the dual pot vaccum advance
I belive the port that is closest to the dist body goes to manifold vaccum, and the one that is further away goes to ported vaccum..
am I correct..??
it's a daily driver Granada.
thanks
Old 04-11-2012, 02:33 PM
DoubleVision's Avatar
I found this info on another board, maybe it will help you.
The Outer port is for Timed Vac. Fords do not advance the timeing while idleing. Timed Vac is also called Ported.
Check your carb vac and at idle if you have vaccum on the port you have a bad carb.
When you set your timeing you shoudl be able to place and remove that vacuum line without yoru timeing moving at idle.
The Inner port is NOT a retard and its NOT for emissions. It prevents a Pre-computered engine from Overheating.
You should have a Thermal vacuum port SWITCH. on top of the manifold with Manifold vacuum to it and usually a couple of vaccum lines from it one Goes to emissions the other to your distributor. When the engine temp gets to high at IDLE it delivers Manifold VAC to your Distrib advancing the timing which increases the idle and the engine pulls more air through the radiator. That riches the mix a bit and WHY there is an emissions componet to this system. The Emissions is secondary to the purpose of the dual vacuum. The purpose is keep your heads from warping when you idle.
Old 04-12-2012, 10:00 AM
Augusto's Avatar
thanks a lot, I tought it was for retarding the timing, I do have a TVS in the water neck and I'm gonna use it, makes sense what you posted, it will work as a mean to raise the idle speed, interesting....
thanks again.
Augusto.
Timing question! and vaccum advance Mad56 Engine 8 12-28-2009 09:03 PM
Vaccum advance can... boost retarder ? Augusto Engine 16 12-02-2008 08:29 PM
Total advance, initial, mechanical and vaccum advance Can anyone break it down Please Brawler Engine 2 09-07-2007 07:25 PM
Need New Distributor: Vaccum advance yes or no? riflegunbuilder Engine 4 09-30-2005 08:13 AM
305 Vaccum advance issues HerbMarshall420 Electrical 2 06-26-2003 11:32 AM
