Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dual Quad vs Single big carb
Old 05-29-2006, 07:58 AM
GoneNova/406's Avatar
GoneNova/406 GoneNova/406 is offline
most all the info i've come across says stick with one carb,that its as good as two and much less trouble.more will give you only slightly more power but the head aches you get for that little more are not worth it.on the other hand the eye appeal gives it that,yea thats right i've got it and i can use it sort a thing.i don't suppose you need to worry about that with 496 though do you?going with one will afford you some lattitude in using an exotic single intake.since i first saw it in a magazine i've wanted to get a tork link or some of the exotic offenhauser intakes.they do have the one that changes tops fron single to double to triple if you really want some variety.good luck
