Dual Rear Axles? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2011, 06:39 PM
The mobile view is crap
Dual Rear Axles?
I have this thought pondering around in my head about a "Recovery Team Vehicle"
I have a 95' Chevrolet K1500 and an 89' K1500, I am thinking about taking the rear end from the 89' and installing it in the 95'. I am thinking of moving the rear end in the 95' forward to make room for the second rear end. My question is how would I power the furthest rear axle? I was thinking of somehow installing a second transfer case behind the first transfer case backwards? Will a transfer case run and operate correctly if it was installed backwards?
So to clear up some of that jabbering: My thought is to install a second rear axle and a second transfer case backwards behind the oem transfer case. The oem transfer case would power the front differential and the second transfer case, then the second transfer case would power both rear axles. So I would still be able to power the vehicle with just one rear differential with both transfer cases unlocked.
Old 01-24-2011, 07:03 PM
Here is a stupid little very quick sketch
Old 01-24-2011, 07:58 PM
bigdog7373's Avatar
Of course it's fast
The first axle is a kind of straght through design on 6x4 trucks. It goes in the front and out the back then to the 2nd axle. Heres a diagram, a simple one at that. Do some research on 6x4 trucks.
Old 01-24-2011, 09:09 PM
I don't want to power all 4 rear wheels at the same time though, maybe I will have to just spend some time in the garage pondering this with all the parts in place.
Old 01-24-2011, 09:18 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i think i understand what you are saying about the transfer cases.
and i think you could make it work, but something might have to be reverse rotation to get everything spinning the right way.
the problem is getting the driveshaft to the second rearend because the first rearend will be in the way.
Old 01-25-2011, 01:59 AM
bentwings's Avatar
bentwings
Why not just make a duallie instead. You can get nice kits for this.
Old 01-25-2011, 06:34 PM
I don't want a dually, I want dual rear axles if I do anything at all.
My thought on the second transfer case was to have it so the "front driveshaft" part of the transfer case would be vertical to go over top of the first rear end and attach to the second rear end.
Old 01-25-2011, 06:44 PM
& matts38chev
i think i have seen something like this, so it can be done
1968-1970 12 Bolt Rear Axles Same Length? YARDFISH Transmission - Rearend 3 11-13-2010 02:22 PM
9 inch Ford rear axles rhphotrod Transmission - Rearend 10 08-14-2010 11:51 AM
Procedure to remove rear axles? HotRodMan Transmission - Rearend 4 04-16-2010 07:26 PM
rear and front axles demon1 Transmission - Rearend 0 09-18-2007 09:47 PM
Ford rear axles 19SS64 Transmission - Rearend 4 07-08-2006 11:23 PM
