Dual Stromberg 97 hesitation - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2012, 11:40 PM
south65ss's Avatar
Just started my 239 Merc with Offy intake and dual strombergs. Have had some flooding problems but after a fuel pressure regulator its running almost ok. Now it hesitates when I step on the pedal. Should I run both carbs accelerator pumps or just one? Maybe is it normal to hesitate when all four barrels open at the same time? It runs just fine after that, it revs very good.The problem is just off idle. Any idea?
Thanks
Old 06-12-2012, 07:40 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
It's getting to big of a shot of gas, change the location to a lower hole on the accelerator pumps or try just one like you mentioned.
Luv the smell of NITRO in the morning.
Value of Stromberg 97s' ?? Gr8lite General Rodding Tech 2 11-20-2005 03:50 PM
alky stromberg 97's FEDDO Engine 1 07-03-2005 11:30 AM
stromberg rockett88 Introduce Yourself 1 01-06-2005 07:47 PM
Why Stromberg? MARCELO URUGUAY Engine 2 11-08-2004 10:13 PM
Why Stromberg? MARCELO URUGUAY Hotrodders' Lounge 8 11-08-2004 09:12 PM
