Dual TBI Setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2010, 06:22 PM
The mobile view is crap
Dual TBI Setup
I am sure this has been talked about before on this forum or maybe another. I was kind of curious if it would be plausible to setup a dual tbi setup on a sbc. I know holley makes their 670 cfm throttle body that would be large enough to feed a healthy 383, if their injectors are large enough? I just think it would look cool and be very unique! I think the problem would come in trying to power 4 injectors instead of two? Is there any way to deliver the correct amount of voltage and fuel to two throttle bodies? I don't really want to hear about other fuel system recommendations I am just curious if this would work, or if it has ever been successfully done before?
Old 12-30-2010, 10:53 PM
406cu.in. of tire smokin' fun
Last journal entry: 406 Build Thread
It's possible. You'll need to talk to Bob at dynamic-efi.com. He is an amazing source of information and manufactures the stuff you'll need to make it all work; both hardware and software. Keep in mind you will need to do the tuning yourself, but he has good instructions/definitions/forum support for it.
Even with a single, it will need to be tuned. If you don't, you are leaving a lot on the table. A single TBI would be enough but you'll need to run more pressure to it. If your injectors have the dome top, replace them. They are garbage. When I had my TBI, I just used the Holley TBI and used factory GM injectors and injector pod.
Good luck.
Old 12-31-2010, 01:01 AM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
GM actually ran a dual TBI setup on the early 3rd Gen F-bodys and 4th Gen Corvettes. It's called the crossfire injection or CFI. I don't think it was around for more than two model years, but I'm not too knowledgeable on the subject.
Old 01-01-2011, 05:37 PM
pontiacjosh's Avatar
84 stroked ss
Last journal entry: exhaust
i believe they stopped producing them because they had 2 many problems with them
Old 01-04-2011, 08:36 PM
tnovot's Avatar
No real problems with the Crossfire but they were designed for fuel mileage and emissions, not power. Crossfires got a bad rap and many who don't know the true facts, perpetuate the falsehoods.
I had one in my 1984 Corvette and it had plenty of power for me, always started well, pulled hard through the gears, and got good mileage when in overdrive. There are limited speed parts because of only being produced for 2 years (1982 and 1984) in the Vettes and maybe a couple of more years in the Camaros.
The 1985 and up fuel injection systems made more power. The crossfires were reliable but AFTER A FEW YEARS, THERE WERE FEWER AND FEWER GUYS WHO KNEW HOW TO TUNE THEM PROPERLY.
Terry
Blazer dual piston setup Vs. SSBC dual piston calipers! veltboy314 Suspension - Brakes - Steering 1 11-28-2010 07:37 AM
Dual radiator setup. ForceFed86 Hotrodding Basics 9 04-26-2010 09:55 PM
Electric Dual Fan Setup stfinney Engine 23 05-26-2008 12:15 AM
Dual Quad setup chevyIIdie4 Engine 8 06-23-2003 10:31 AM
Dual Quad setup Hipohealey Engine 3 05-27-2003 08:18 AM
