dually to single rear wheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2014, 07:11 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
First off wasnt sure where to.place this...so.feel.free to.move if needed.
So I bought a 99.5 f350 7.3 psd 4dr cc longbed dually.I am never gonna pull a 5th wheel & since Im lifting the truck & going with bigger wheels & tires I want to.eliminate the outter rear wheels & whatever it takes to make it a non dually without swapping the axle.Anybody done this before?I.plan on doing this soon so if you can help please do.Thanks in advance
Old 08-22-2014, 07:28 PM
ericnova72's Avatar
More for Less Racer
No difference between the 3/4 ton and 1-ton axle except the length of possibly the wheel studs, the housing and axles are the same. Other than the flared box side extensions there is really no difference between the two trucks, along with spring pack sets for the different weight capacity.
The Following User Says Thank You to ericnova72 For This Useful Post:
crussell85 (08-22-2014)
Old 08-22-2014, 07:29 PM
Wiki Edits: 31
IIRC The entire rear frame is different on a Ford. I may be wrong but still that hurts the value of a quite valuble truck... Buy the truck u want
Old 08-22-2014, 08:00 PM
two cups of tea
Wiki Edits: 2
fhats why Im not swapping the axles with someone that wants to go drwImcasenI ever wanna go back. I.woulda bought a srw powerstroke but this was a steal.Kinda one.of those deals that you always hear about but never get.Its my understsnding that basically all I have to.do is pull the front spacers then just pull the rear wheels off?
Old 08-22-2014, 08:36 PM
ericnova72's Avatar
More for Less Racer
I believe you are correct with the spacers and wheels....at least that is how all the older stuff is....just get the backspacing right on the single replacement wheels and it looks good, I've seen 4x4 1-tons done this way with big mud tires, just cant haul a 1-ton load because of the load rating on the single tire.
Old 08-22-2014, 09:00 PM
two cups of tea
Wiki Edits: 2
yeah I reallu like the dually look on a lifted psd but those damn tires&wheels cost sooo much.Im about to go try 2 hunt down some tire info. Anyways I cant find someone who hasactually done the drw to srw or a write up
Old 08-22-2014, 09:26 PM
carolinacustoms's Avatar
Automotive Extraordinaire
How much lift do you want and what size tires are you wanting? It's hard to beat the look of a bad ***** lifted fat bottom.......
This guy is running 6" lift 37x12.5x17 with 2" hubcentric spacers to keep the rears from touching.
315/75/16
Kelly
Old 08-22-2014, 10:50 PM
two cups of tea
Wiki Edits: 2
20 in.wheels with 35s-37s 9 inch lift
Old 08-22-2014, 10:51 PM
two cups of tea
Wiki Edits: 2
id.like 22.5 semi wheels...too.expensive
Old 08-23-2014, 06:08 AM
The mobile view is crap
From what I am understanding your wanting to remove the dually fenders and run a single rear wheel, right? Have you thought about running a wide tire and wheel in the rear to fill the space of the duals?
Old 08-24-2014, 04:50 AM
two cups of tea
Wiki Edits: 2
Yes that was actually the 1st option.I weighed.The.problem.is the super singles is the cost the & there hard to find I wanna run rockstars or motometals.I can get those for 250 to 350 a wheel for srw duallys gonna be atleast 1200 more,Id love to run the suoer singles but cant find none that Are not gonna cost the same as a new truck
Old 08-24-2014, 08:05 AM
Wiki Edits: 31
I guess I don't get lifted full size trucks.. I just had my stock F-150 up in the hills yesterday on one of the trails, and yea I scrubbed a bit, but it did fine. The width and length was the problem.. I can't see a CCLB working well
Old 08-24-2014, 08:40 AM
It's about looks. Most lifted diesel trucks never leave the pavement.
I've never cared for much more than a body lift myself. To each their own though.
You own it so make it yours
The Following User Says Thank You to crussell85 For This Useful Post:
carolinacustoms (08-24-2014)
Old 08-24-2014, 10:40 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I think a fellow will care once you lift in some engine blocks or fender sections then you will care about that lift and not in a good way..
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
Old 08-24-2014, 01:38 PM
two cups of tea
Wiki Edits: 2
only lifting for looks.I have a lifted ram now but trans is out
can you make a Dana 80 it to a single wheel? only drive chevy77 Transmission - Rearend 6 04-17-2012 12:41 AM
thinkers question on tall tires n dually rear? HemmiGremmie Transmission - Rearend 6 02-27-2012 07:14 PM
14 bolt dually vs IH dually rear??? HemmiGremmie Transmission - Rearend 2 02-01-2010 08:49 PM
Dually rear end swap slomotion Transmission - Rearend 5 06-20-2004 09:50 PM
