Dually Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2013, 11:16 PM
Dually Swap
Hi Guys and Gals I'm swapping out rear diff on my 2000 E350 Van from a single wheel full floating assy to a dually full floater. Anybody know if the spring perches on a 1999 F350 dually pick up are the same distance apart as a 2000 E350 van?
BB
Old 10-21-2013, 11:22 PM
BB
not sure but i can measure mine tomorrow for you since i happen to have a 99 f350 in both single and drw. w.e you do remember if the truck is a commercial cab and chassis, the chassis will be narrow compared to regular pickups just some thing to look out for when your picking the bone yard
Old 10-22-2013, 09:50 AM
Boy that would be great. I've got one spotted on craigslist at a very good price and would hate to miss it. It's listed as a Super Cab but the picture only show a bare frame.
Thanks
BB
Old 10-22-2013, 09:32 PM
i measured both my dually and my srw both are 45.5" wide measuring from the spring centers both are 99's
Old 10-22-2013, 09:41 PM
Thanks but it's not gonna work. The van spring c/c is about 4" wider and backing plate to backing plate is almost 3" wider. That means if I used a
F series rear end the inner tire would be very close to the inner fender well.
Back to the drawing board!
BB
Old 10-23-2013, 02:16 PM
Dual wheels Van Angels
Chromewheel.com Picture Gallery
there is other options to a whole rear end though
Old 10-23-2013, 02:22 PM
Ford Rear Dually Fenders Trucks
Old 10-23-2013, 05:11 PM
carolinacustoms's Avatar
Automotive Extraordinaire
BB
Have you looked into changing to a longer wheel stud and using dual wheels on your van? You may need a spacer for wheel well clearance not sure on that.
Kelly
Old 10-23-2013, 06:07 PM
the spacer he would need is super wide which why i posted up those adapters for drw.
The Following User Says Thank You to monster76 For This Useful Post:
carolinacustoms (10-23-2013)
Old 10-23-2013, 09:26 PM
Thanks guys. I have been looking at this site. They make a steel adapter for both front and rear. That being said I'll just replace my front rotors and that will take care of the front. After checking out the rear I think I will go with a set of adapters. The wheel bearings are the same in both a dual set up or a single wheel set up so that shouldn't be of any concern. The springs are the same width so that won't be a problem. It would appear the a single wheel axle assy is basically the same as a dual wheel set up. Fender are available from
a couple of places.
We'll see.
BB
Adaptors, Wheels, Duality Fenders and Complete Kits - Arrowcraft :: Helping You Handle the Road for over 30 years!
Old 10-23-2013, 10:04 PM
Well I guess I won't just replace front rotors with duaally rotors. Needs special hub also. I'll look into spacers.
BB
1989 gmc dually tranny swap jtlance Transmission - Rearend 1 05-08-2010 05:58 PM
14 bolt dually vs IH dually rear??? HemmiGremmie Transmission - Rearend 2 02-01-2010 09:49 PM
Dually rear end swap slomotion Transmission - Rearend 5 06-20-2004 10:50 PM
suspension swap for 1 ton dually slider in wa Suspension - Brakes - Steering 1 02-09-2003 05:38 PM
454 dually general Engine 5 09-09-2002 10:07 PM
