Duel Mode,Height Sensing,Proportioning Valve
1985 CHEVY SUBURBAN 3/4 TON
10.5 ring gear 14 Bolt Full Floater rear with dual proportion valves. I need a know how to check of this is defective. I also need to know what it looks like inside{ a explosion view. This is the correct term for this year make & model Thanks to POWERRODSMIKEY & his VAST book collection{I'm not telling you which room he keeps them in} ANY & ALL INFORMATION ON THIS SUBJECT IS GREATLY APPRECIATED R
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
Why don't you just undo that circlip.
It'll go back together. I'll bet when you collect all the pieces that fall out you will find there is a pointy thing and a round thing or 2 and a spring. You know it says that if the shaft spins freely the valve is defective. Look at line 7 on the page with bleeding instructions. From my book in the "reading room" Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
Does this truck have rear ABS also? I think I have a fresh CHEV Shop Manual here for this truck if interested. |
Dear Mikey.. .. .. .. ..
Spelunking for microscopic parts after they have left the part @ Mach 1 is less fun than what I am doing now... Quote:
Well its kind of a toss up to weather it turns freely or not its like there is a sliding block in there that moves around when its turned back & forth KULTULZ NO ABS its a 85 has no computer or any of that fancy stuffs {imagine the hell I would be in if it did.} might be simpler too? What kind of book are we talking about? how much$$$??? Could you look in it to see if the info I need is in there? Where can I obtain a pressure Gage & what would be the procedure in using this device? Thanks for your time R
Rob,
Do you have a fax machine, I cant copy and past off Alldata, but I can print and fax if you can receive. Steve |
If it is correct for your application, I will make you a fair deal on it. |
| oil being sucked threw the pcv valve on my 350 sb.. | Robbie | Engine | 23 | 05-08-2004 09:12 AM |
| after market valve covers | Kevin64 | Engine | 7 | 06-22-2003 01:56 PM |
| after market valve covers | Kevin64 | Engine | 0 | 06-21-2003 08:47 PM |
| after market valve covers | Kevin64 | Engine | 0 | 06-21-2003 08:09 PM |
| question on hardened valve seats | stfinney | Engine | 19 | 05-06-2003 06:46 AM |
