The part is a steering arm.
I bet you came close to ruining your interior when that "splits" happened! Thank goodness your weren't at speed on some freeway or busy city street!! The Big Guy has plans for you, pal!
Check the condition of all your steering and suspension components asap, you've had the wake-up call! |
the piece
Looks like a 37 ford dropped axle...I dunno if Super Bell is still doing those but not to worry www.speedwaymotors is still doing those axles..
The piece is called a tie rod arm and if in fact that is a dropped axles you will need the tie rod arms for dropped axle..as to the rotor..dunno sounds like a GM part and the min thk should have a number associated with it as that is the minimum thickness the rotor can be turned to..At least I think so anyway.. BTW: install the new ones with grade 8 bolts and locktite so this is not happening again.. hopefully more happy rodding days ahead.. OMT
More Pics
Thx Pasadena and OMT. I am a lucky guy. This was a wake up call to check things more often.
All these front ends parts take a good pounding over the road.Here are 2 more pics, one from underneath and one from the front. They might help you ID the type or manufacturer of the tie rod arm. We're looking at a '32 Ford, 5 window...dunno who made the suspension, calipers, or spindles. I guess I'm just looking for a place to start looking. Thanks for your help! |
Yep, Speedway sells those steering arms.
If you had been wiping down and doing the service that you should on a hot rod , you would have caught that. Shame on you. Troy __________________ If you don't make mistakes. your not doing anything. 69 SS/RS full custom Camaro 98 ISCA Grand Champion 69 SS/RS BB Camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 SS Chevelle BB conv.fresh frame off 26 T sedan street rod |
It Won't Happen Again
No excuses here. I haven't been paying attention. It won't happen again! Actually, I'm ready to start a re-build on this old ride when I get the bucks together.
Meanwhile, would you say that this is a possible match for what I need? Tie Rod Arm for Dropped Axle |
when you go to put it all back together make sure you use grade 8 bolts with the loctite like ONE MORE TIME said but also use TOP LOCK nuts so that stuff wont come apart till you take it apart
yea good thing you did the split @ extreamly low speed it would have been a big mess glad you are ok sr66
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
Where to Buy a New One?
I've sent Speedway a pic and they say they don't sell the steering (or tie rod) arm that I need.
Does anyone have any idea of where or what I might try next? Thanks. |
steerin'arms
Flash, that piece looks identical to the pair I bought from Speedway about a year ago, I found them in the "hotrod"section of the speedway catalog, under "flame cut arms" Perhaps you got "serviced" buy a new guy when his "mentor" wasn't lookin'. Usually the tech folks are much more helpful... try 'em again, if it's still a *** answer, PM me , and I'll lookup the part number on the invoice... Paul
Try this
Speedway part number 916-32033 that is for the plain tapered lower tie rod arms..from what I see in the pics they should work...what I am seeing is that this is a dropped axle but then they ran the tierod through the center of the radius rods and this car has the traditional drag link steering..
Worst case is to order a set and have to send them back as I see it..they are 50 bucks in my catalog for the set and you will need to change both sides...least I would.. OMT
I forgot to be serious !!
Sorry about that, I was havin so much fun, I forgot you had a real problem. Anyway, just looking at your pictures, it looks like what you need is just some bolt on steering arms. Replace them both, as they are usually sold in sets. Magnum Axle, Pete and Jakes, Super Bell, TCI can all help you to get the correct one’s. but remember, this is a Hot Rod, be ready to do a little “tweeking”, if needed. Ditto on the Loctite and Nylock nuts. also grade 8 hardware; yada, yada, yada.
Fifty Bucks for This?
I'll tell 'ya what onenew32, I'll sell the wife for $50.00 and throw in the car for free if you'll haul them both away and pay-off her credit card bills. BTW, the car would probably fit on your trailer but the wife definitely won't.
Thanks, olesixrod and onemoretime for the advice. I'll call Speedway this time rather than emailing them. I'll also insist on talking to a "mentor" and will give them the part number. If Speedway doesn't do it, I'll try onenew32's list. Thanks, buds! Flash |
Making Progress
I bought Part #702-2760 from Speedway's Street Rod Catalog on page 6. I really like this part. It is beefier with a lot more metal around the mounting holes than the one I took off.
I think the old part was probably the thin metal lower tie rod arm #916-32033 shown on page 7 (there just isn't much metal around the mounting holes). I think the guy who built this car bent the part to make it fit the dropped axle. Anyway, I'm happy to have the new part even if it does cost me new (shorter) tie rod and a new drag link (maybe even a new pitman arm): man, there is just too much depending on that little tie rod arm to be chinzy with the metal around the mounting holes! BTW, does anyone know what shock we're looking at here? I think I'll replace both of 'em while I'm at it. Thanks for your help!
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| power steering | Paco | Suspension - Brakes - Steering | 9 | 10-31-2006 06:02 PM |
| Problem: Steering Rack? | horvath | Suspension - Brakes - Steering | 64 | 06-15-2005 08:11 PM |
| Question about removing roof | 86caprirs | Body - Exterior | 3 | 03-27-2005 12:21 PM |
| Hotrodders Knowledge Cluster: Power Steering Conversions | Jon | Suspension - Brakes - Steering | 0 | 09-03-2003 11:20 PM |
