when we ever had a dullness issue, the clearcoat or hardener was at fault, not the technique. |
I said nothing that disagrees with what you have said. What I am saying is IF you were to apply it that wet (near run) you had BETTER have all the other reasons for trapped solvent under control! 1. Atomize the clear properly so when it comes out of the gun it hits the panel and the majority of solvent is flashing off. 2. Use a faster pass with less overlap. 3. Leave it longer to flash off between coats. 4. Shoot it in warmer temp shop and METAL TEMP (an ice cold car sprayed in a warm room/booth is no better than a cold room/booth) so the solvents flash properly. 5. Chose the proper reducer and hardener for the metal and booth temp. 6. Apply fewer coats. And if you do all the things proper with proper atomization you more than likely don't need to over reduce it. It's like I aways say FOLLOW THE TECH SHEETS. If we were to follow the tech sheets to the tee, it is going to work. If one has to deviate from the tech sheets for a particular "only in my shop" kinda problem, sure, not a problem. But you can't deviate from the whole tech sheet, it simply isn't that forgiving. It's like many things in life, you can go and hang out on the edge of the line on something and it will work fine, but you can't hang out on the edge on EVERY line. You know what I mean? Believe me, we are on the same page. If I have communicated it wrong, that's on me. But we are on the same page. Brian |
I say "part" of the problem because it doesn't do this on every single job it is used on. If it did they wouldn't sell a bit of it. It works somewhere for someone. Often it's more about "the planets being aligned" where there are more than one seemingly little issue is aligned with other seemingly little issues and combined you get crap. Brian |
I've heard a lot of good things about Matrix never anything bad ,I've never used it myself .
when it comes to newbies theres always the luck factor, some guys can do everything wrong(like me) and still get a good job. I've always been lucky when it comes to paint...One time I ran out of clear hardner (not to long ago actually)on my last coat and substituted about half of it with a primer hardener without any problems at all ,I totally expected it to do something crazy but it didnt ... it was sunday night and the car had to go monday at noon so if it wasnt ready there was going to be a good reason that I could blame on the painter (me, but they dont know that) not something lame like, sorry I ran out of hardner you'll have to rent that car another day...a little prayer to the paint Gods when I do something I know is stupid cant hurt either and I do it...But I still do some major screw ups like mixing 1:1 sealer at 4:1 y,ou want to see a clear get dull try that sometime or put to much base on way to thick and without realizing it and rush the clear because you want to get home ,it looks great when you leave but when you come back the next day and no shine at all...Theres a lot of ways clear will dull out even the temp change at night can do it.. Who knows what the actual cause was ,all we can do is make an educated guess..pay your dues when this stuff happens and do it over being double sure you follow all the directions to the tee.You can only get better.. |
| Spray clearcoat over clearcoat, should I sand first? | klingfilm | Body - Exterior | 4 | 10-14-2009 05:36 PM |
| sanding clearcoat problem | ricksautorestoration | Body - Exterior | 3 | 09-08-2009 09:43 PM |
| a little dull | awert | Body - Exterior | 3 | 05-30-2008 09:24 PM |
| Clearcoat problem.... | STATUTORY GRAPE | Body - Exterior | 19 | 04-03-2007 07:25 PM |
| Light clearcoat problem | moor3061 | Hotrodders' Lounge | 2 | 07-06-2004 12:32 PM |
