dumb or dumber pinion help?
i bought a 92-94 rack pinion thinking that well hell i have a 2000 rear axle/diff attached to my rear on my 67 stang...i should be able to attach the pinion in front with some adjustments
...but the mechanic here tells me no way...anyone can give me advice or and i just screwed ???
Just bolting it in you are completely changing the entire steering geometry which changes the bump steer, bump camber, and bump caster. Without some pretty intense research, you could really ruin the handling to the point of being dangerous.
Apocalypse aside, you are not screwed. Several others have probably already done this and done the math for you. I suggest hitting a dedicated Mustang Race forum or tech page and seeing if someone else has done it before. It might be as simple as a pressure regulator on the supply line and some new tie rod ends, or it could be as complicated as a complete new font subframe, spindles, springs, shocks, welding, cutting, fabricating, and swearing ![]() But, don't take it lightly. Steering and suspension geometry is a very precise concept and an understanding of how changing things will affect how it behaves on the road. One degree can make the difference between a safe ride and a handful. |
There are plenty of high dollar bolt on racks for your Mustang. Unfortunately, most of them dont give a sideways cr*p about steering geometry.
The only rack I'm aware of that has been made to work properly is a GM J-car (Cavalier) rack, because the tie rods attach near the center. It still needs a lot of custom work to get it right. I believe a guy named Sixto Bernal was engineering one for his Mustang, but I can't seem to find any good links. |
| Pinion Angles and Driveline Setup for the Street | Centerline | Suspension - Brakes - Steering | 32 | 05-11-2007 07:22 PM |
| how to determine correct pinion angle | upthcreek | Transmission - Rearend | 2 | 12-22-2005 07:58 AM |
| penion angle | wolfemanbud | Transmission - Rearend | 2 | 10-04-2005 06:58 PM |
| Pinion Angle Mystery | Dep ME | Transmission - Rearend | 17 | 08-18-2004 12:02 PM |
| 12 bolt Chevy truck pinion question | Gametech | Transmission - Rearend | 9 | 03-09-2004 05:02 PM |
