And furthermore when I change over to braided steel will that brass fitting just back right out of the carb body so I can replace with a AN fitting? Or is there something I am missing? Oh, and don't mind the fluid laying all over the top of the engine. The knuckle head also ran the engine without a PCV valve.
Right front side of the air horn (as you sit in the driver's seat) is where Holley usually stamps in a set of number. Pull the air cleaner and you should be able to find it.
It looks to be a 600..........As IC said, take a look for the numbers stamped where I put the arrow.....It will say "List-****".....You then look that number up...
It could be a factory carb (GM, Ford, Chrysler)....some of them have weird numbers, a bit harder to look up
Ontario Rodders |
Ontario Rodders |
![]() Your Holley is a Model 4160 vacuum secondary "single feed, single pumper"-type carb. Sizes vary among this style carb, so use the List number (location shown above) to determine exactly what you have, size-wise. The "banjo" fitting has a pair of small gaskets that seal both sides, it does just unscrew normally (CCW). Earls, Russel, etc. along with Summit sell the lines and AN fittings you want. The size of the fitting into the carb itself is male 9/16-24 , to whatever AN size you would like, usually -6 (3/8") is sufficient. Good luck, looks to be a good project. |
Seems I was typing while everyone else was posting.
The "0778" is a date code. 77th. day of a year ending in "9"- probably 1999. |
Yes, eventually that rubber line will wear through. I myself am guilty of going the cheap and easy route on my beaters and using rubber fuel line and have often used the alternator bracket as an anchor BUT I always run them through a section of heater hose anyplace that might be a rubbing point or could be subjected to heat like a coolant line.
True you never know who might be reading. And yes it appears to be a 600. JMO Cole |
I had to disconnect the battery just to keep from worrying about my garage burning down. Honestly I don't think the guy I bought the truck from is the culprit as he is not the orginal builder.
Yeah, I can imagine LOL. I had one of those and I posted several rants about it here last year. Calling whoever did the work on it a "knuckle head" would have been a compliment but I was careful not to post any pics of it and the person that did the work didn't frequent the internet much less this site. |
| dumb dumb wheel question...5 lug steel rim? | MUSTISIXSTANG | Suspension - Brakes - Steering | 4 | 06-07-2010 07:27 AM |
| removing old holley gasket material & couple other holley questions | darkostoj | Engine | 6 | 06-30-2009 07:06 AM |
| Holley newbie... some questions | curtis73 | Engine | 5 | 03-25-2007 06:29 PM |
| Am i dumb | Mrwood | Body - Exterior | 11 | 11-12-2005 08:45 AM |
| Dumb newbie needs wiring help | Bob23T | Hotrodding Basics | 12 | 07-01-2004 06:40 PM |
