Dumb newbie needs wiring help
Hi all, new to the board. Got a wiring question. I'm building a 283 for a t-bucket and would like to run the engine, but don't have anything wired yet. What is the minimum wiring I would have to do, to run the motor. Like I said its a 283, I'm using a mallory dual point distributor and standard 12 volt coil.
Hope thats enough info. Thanks for any help. Bob |
i also own that
same harness its easy
12 Volt battery, ground cable to the block, positive cable to the starter, jumper wire from battery " + " to the " + " terminal of the coil, " - " coil wire to the distributor, touch a screwdriver from the battery cable on the starter solenoid to the " S " terminal on the solenoid to crank it over and it should run. Disconnect the jumper to turn it off.
got it goin
Hope camaroguy helped you. I did the same on my 40 chevy with a 350, didn't even hqave the front clip, radiator or any thing on it. DO NOT RUN IT LONG ENOUGH TO GET HOT. I had my adusted and broken in before i got it together. Makes a body feel good to hear it run, after so much work, and being on a limited budge. Hang in there, you get there.
I agree. I have a magic box that I use in my shop. ( Toggle switch. button switch and ignition On indicator lite) three wire hook up and your good to go. Bob asked the minimum and my other answer was the minimum.
Maybe ... but I always do a ground strap to the frame (as you suggested) and then another fatty (8 gauge) wire from the frame to the firewall just to be sure there's a good clean ground happening.
Alan 54 Chevy Pickup |
Hey guys, thanks for the replies. I got just the information I was looking for. I was pretty sure what to do, but you all verified it for me. Thanks again.
Bob |
