Dumb Question #54
Allright, I saw this car on the net, and it said it had a 1932 V8 flathead, but if you look at the engine, there's only 3 exhaust headers
but 4 spark plugs do the 2 middle cylinder exhaust ports merge into 1??Thanks Mike |
Good guess! You are exactly right. Every flathead ever made was configured like that.
Cool
Thanks, Mike |
Mike,
A little test... When you see a flathead with a head off, you will see the 4 cylinders with two valves just above each one. With the information you now have, how would you identify each of the 8 valves as being intake or exhaust? |
Dang, you got me there
My best guess would be that the intake ports will all be separate and the exhaust valve ports will collide into one exhaust port (the 2 middle ones of course)
Mike |
Not quite...
it would be ex-in-in-ex-ex-in-in-ex |
And that is the reason those bad boys are a bear to cool. The exhaust port is at the top of the cylinder and runs all the way through the water jacket to the bottom edge of the block. Coolant is trying to quench 1000F exhaust runners!!
