dumb question about oil filters - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2008, 10:43 PM
Bill-E-BoB's Avatar
Last journal entry: A years worth of catching up
I've got a '55 Caddy with the 331 engine. I went to do an oil change on it because I don't know how long the oil in there has been sitting...and there's no oil filter on that thing. Is that right??? This may be the most basic and dumbest question ever to hit the board...but what do I do about filtering the oil? I drained & replaced the oil. Is that all I do? Do I change it more often than the ol' 3k/3mo rule? I use 10w30 high mileage oil, is that cool?
Old 06-29-2008, 10:52 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
I have never been near an older Cadillac engine so.....
Back then fords had a canister type oil filter. They were fastened onto the block where a normal filter would go. You replaced the inside part and put the outside back on.
My 56 ford F-100 is supposed to be that way. Someone (somewhere along the line) put a screw on oil filter conversion kit on it. I just use the same FL-1A motorcraft filter as every other ford does now.
Truthfully, I have never seen one in person. Most have been converted for convenience and stopping a mess with oil changes.
Old 06-29-2008, 11:17 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
It should be a cannister style alright, according to Wix Fiters part number 51100. (1955 Caddy V8 All)
I had a '55 Pontiac with a (261) 6-banger which I'm sure used the same filter. Wix's online catalog only goes back to '56 (Chevy full-sized pass car) and shows the same...
Mine was mounted remotely on the exhaust manifold, and had two rubber hoses coming up from the side of the block.
Old 06-29-2008, 11:34 PM
sbchevfreak's Avatar
Licenced Automotive Technician
If it does not have the filter '66 showed, it is possible it doesn't have one. I serviced a 1940 Caddy once and it had no oil filter on it. It was 15 years older, though.
Old 06-30-2008, 06:22 AM
31 five window
Last journal entry: Moving along with patch panels.
I have an all original 55 Caddy at my house right now. I am rewiring it for a friend. It has a canister type oil filter on the drivers side.It is mounted above the valve cover behind the power steering pump.Hope this helps.
Old 06-30-2008, 06:24 AM
Wiki Edits: 31
until the advent of detergent oils in the 60's, oil filters were optional, so it is likely it does not have 1... however I would not run high millage oil in anything.. not only does most of it have stop leak capabilities. it has a lot of extra cleaners and detergents in it, which might be ok with an oil filter, but w/o the filter, you are carying that stuff thru the engine
Old 06-30-2008, 06:35 AM
Irelands child's Avatar
The second canister back is the oil filter - the forward (and tilted) canister is the power steering reservoir.
Oil filters were standard not optional like those on "lesser" cars like Fords, Chebbies and Plymouths .
If yours is missing, then someone removed it somewhere in the past
Dave W
Old 06-30-2008, 09:09 AM
Bill-E-BoB's Avatar
Dave W
Ahhh, ok. I've got that one on there still. The dude I bought it from told me that was the brake fluid reservoir, & I hadn't had any reason yet to question him. I'm a moron. So...how do I service it? Just take the cap off & replace an element like you would do with the air cleaner? Or is it a foam one I have to clean out with like WD40 & compressed air?
*edit*, nevermind I get how to replace it from the other posts in the thread...I just woke up, I'm a little dopey right now.
Do NOT buy AC Delco Duraguard Oil Filters!!! indy_85stariones Engine 75 07-06-2009 02:19 AM
Synthetic Motor Oil In 454 Rebuild leejoy Engine 36 11-20-2006 02:34 PM
Blower gear oil question Arrowhead Engine 4 03-29-2006 09:15 PM
Wix Racing Oil Filters??? camaroman7d Engine 4 03-20-2006 07:28 PM
Oil question! Ratoflic Engine 17 02-09-2005 11:23 AM
