Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dumb question that i should know the answer to.. shrinkage
  #18 (permalink)
Old 10-07-2005, 01:24 PM
MARTINSR MARTINSR is online now
An example is in my gun set up "Basics":
As an example of the use of a 1.3 tip I did a test once that proved the point well. I shot two panels of metal with a med solids urethane primer. One was shot with a 1.3 super high atomizing top of the line topcoat gun. The other was shot with a 1.5 (or a 1.7 I can’t remember) “hoser” primer gun. Three coats were applied and after a full cure (the one shot with the larger gun took MUCH longer to flash and cure by the way) the film thickness was measured. The one shot with the 1.3 tip was 2 tenths of a MIL thicker! The larger gun laid out the marble sized droplets full of solvent and when the solvent flashed the film shrank.
Now, the 1.3 tip may be too small for some products so check the tech sheet. The facts of the findings won't change.
