Dummy Newb Q--Can I get metallic paint without the metallic? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2008, 08:28 PM
I think its a simple question, but I dont know much of anything, so here goes
I will sometime in the near future (by which I mean hopefully in the next year or so) paint my first car. I'll be primering with SPI epoxy and am still debating the final BC/CC combo and brand. I's really like to do a urethane, but I'm worried as all get out about the isos. (I'll be doing all this in the backyard (I know I know, less than optimal.)
But what my main question for this post is--can I get a metallic paint without the metal flakes? I'm really pretty hung up on the mini cooper indi blue, but its a metallic. Can I give the code to a jobber and have it mixed without the flake?
And if yes, how much is this likely to affect the color?
Old 10-06-2008, 10:04 PM
is it a heavey flake?? im guessing not if its on a mini cooper. im sure they would mix it without the flake but it might change the look of it a little. the flake is a big effect to the paintjob of that color.why not look for a color that was close to the blue that doesent have flake in it.
Old 10-07-2008, 04:58 AM
I'm a dupont sponsored bodyshop so I mix all of my own paint (cromabase). What seems to be metalic isn't. I haven't used actual flake in over 10yrs. What that metalic actually is is course or fine alum silver paint. Your jobber will have to play around with it to get the color you want without the metalic effect but it can be done. Also be prepaird for him to charge you for experimenting because he's going to waist some paint till he gets the color your happy with.
Old 10-07-2008, 10:47 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Look into House of Kolor..the metallic effect is in the base coat with a top coat of the color then clear..if you use a base with no metallic effect in it you will get a plain no metallic color for the finish..
Sam
Old 10-07-2008, 04:16 PM
Have a helpfull jobber look through the millions of colors available, and he can probably help you find a solid color formula that looks close in hue to the color you are looking for.
If you leave out the flake in the formula the color will likely be darker. Even so a solid color is not going to look exactly like a metallic, the metallic and pearls play with light and reflect it, and gives the color its glitter effect, or even change the hue on areas light hits, and gives the color flop.
Need advice on a paint job tishmomo Body - Exterior 36 01-15-2008 11:19 AM
single stage metallic paint with flattner jpkoehler Body - Exterior 1 05-09-2007 02:55 PM
Getting ready to paint my vette lot of questions zr1salvage Body - Exterior 17 03-12-2007 05:57 PM
Cost of paint Job - complete do it your self job at home Warrant Body - Exterior 74 07-13-2006 09:31 PM
Metallic Paint - splotchy look bruce-77346 Body - Exterior 1 05-25-2003 07:09 AM
