dumping fuel in oil - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 02-29-2012, 12:33 AM
dumping fuel in oil
it's a1990 Corvette 350 Base model, new fuel pump, new filter, new pressure regulator, new wires, new cap and rotor, new intake manifold gaskets,new plemumn gasket new sensor, waiting on hose from heater core to surge tank so no antifreeze yet, gas just fills up oil as soon as I try to start it, it runs for a few seconds then fouls out and it never idles, there was 2 plugs under brake buster, one was fuel pump check connecter the other made the fuel pump run with key on, I hooked it to the battery Positive, should it go some place in the harness, if so where thanks for your help
Old 03-02-2012, 09:02 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Your injectors are most likely going to full open when you hit the key for some reason. This means that the ECU is enabling the fuel pump and all the injectors at one time for some strange reason. As to what is causing this...not sure. If you had a known good ECU you could try, I would start there.
Old 03-02-2012, 09:03 AM
TurboS10's Avatar
Wiki Edits: 2
Wait, did I just read that you hooked the fuel pump to the battery? If so, is it running constantly with key off?
Old 03-02-2012, 07:03 PM
EagleMark's Avatar
GearHead-EFI.com
You can do that and fuel will just flow through return line to tank. All GM systems run 2 seconds key on to prime system before starting.
But they do not open an injector!
Unless you re-wired something very wrong I don't know how the ECM is opening an injector? You may have a faulty injector stuck open?
Recent Modern Electronic Engines posts with photos
OK I'm dumping the 993 Heads but which flow better? 50BLUECHEVY Engine 35 08-30-2011 03:35 PM
trans dumping fluid burnt olds Transmission - Rearend 7 02-24-2010 12:05 PM
th400 dumping fluid zephyrc Transmission - Rearend 1 09-01-2005 09:23 PM
Dumping the ECM malc Engine 12 09-19-2003 02:56 AM
