Dune Buggy - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2008, 04:15 PM
Dune Buggy
I have someone that wants me to paint a dune buggy using metal flake. After bodywork, primer/sealer , spray base then apply metal flake mixed in intercoat clear ?? Apply clear after this ? What size flake to use ?
Old 07-01-2008, 04:59 PM
I have to tell you, first off, I am no custom painter. But I have sprayed a little "flake" like the old dune buggies had from the factory. I like to call it "Bass boat flake". It is sometimes sprayed in a urethane clear. But you can also "dump" it on, or spray it out of a gun without any clear, just the flakes. It takes a LOT of clear to bury this stuff! I mean, a LOT, many, many coats.
Do some test panels before you try it on such a job.
Old 07-01-2008, 06:55 PM
Old Fool's Avatar
try and talk them into the smallest flake size possible, that will save you a lot of work, not to mention a lot of clear.
Beach Buggy Danie du plessis Introduce Yourself 1 09-13-2007 06:41 AM
VW Dune Buggy? MrPhotographer06 Hotrodding Basics 3 08-06-2007 01:57 PM
Dune buggy Checy_Guy Hotrodders' Lounge 4 03-15-2004 11:58 PM
dune buggy from car frame? kermit49464 Engine 3 11-11-2003 06:46 PM
31 ford rear buggy spring lnwlf Suspension - Brakes - Steering 1 11-12-2002 10:07 PM
