Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dupli Color Paint Shop auto paint Lacquer
  #115 (permalink)
Old 11-16-2008, 05:50 PM
matt167 matt167 is offline
Wiki Edits: 31
I'm not trying to cause an argument.. because I know it makes no sense to use lacquer, when Acrylic enamel or single stage urethane can be had for ( often times ) less money than lacquers.... given the downfalls, and cost disadvantage, it makes no sense to use it.. All I'm pointing out is that it's not nessasarly a bad product, but a severley outdated product.
you could point it to bias ply tires, and drum brakes too... there not nessasarly bad but they are outdated.. they were once considered good... inferior today yes, but that does not make them bad... that's the only point I'm trying to make...
And I would agree. Lacquers downfalls should be known.
