The instructions in Step 5 on the can hint at the durability of this paint system. You have to "buff with a random orbital waxer/polisher using a wool buffing pad and 1500 grit rubbing compound..." The instructions specifically state "Do not use a high-speed buffer as they are too agressive and will damage the paint surface." No one has ever paid me to paint a car so I guess I can't be considered a professional. However, you pay the exact same price for my advice as you do for the pro's on this site: $0.00, less than the proverbial two cents. My free advice is: Don't spend money on the Paint Shop System. If you absolutely have to shoot some lacquer, go to www.PaintForCars.com -- they sell three dozen colors for $79-85 a gallon and that's not thinned. I have two gallons of their gloss black that could get you started. I sure don't want it. I was born in 1944, before the first Hot Rod Magazine was published and my first hot rods and customs were plastic and made by Revell and AMT. Painted those with sable brushes and tiny bombs of candy apple enamel (I assume they were enamel because lacquer would have melted the styrene plastic). In 1962 I painted my real car, a ’56 Chevy, with a nylon brush and red devil enamel. Had to do it at night, after work, in the driveway. Probably would have turned out better if it hadn’t started snowing halfway through. Paint was old so I couldn’t read the instructions. Probably wouldn’t have followed them if I could. After all those model cars, I was an experienced painter. Had there been little foam paint rollers back then, I probably would have copied the Hot Rod Magazine article on painting a ‘62 Falcon with Rust-Oleum and a roller (that’s from a 2009 issue). If price is the objective, they managed to paint the Falcon for $98 and that price included masking tape, sandpaper and a bunch of stuff not mentioned in the DupliColor process. The two quarts of Rust-Oleum and gallon of thinner came to $22.91. If you really don't care what the car looks like, spending $100 seems like a better deal than the DupliColor. Especially if you don't have a compressor, spray gun or mask. Hot Rod's process didn't even require priming or clear coating. Looked about as good as that Bronco on "Trucks" but the Falcon had a red scallop rather than black and gray lighning bolts. |
LOL, What your forgetting is how it fits the market and is not intended for the pro or semi pro but the guy that has zero skills!!!! that does want to paint with out the big learning curve!! A job he can do in his garage. I can see a ton of reason Why! You don't need any fancy equipment booth or offend the guy next door with the smell. Price don't seem to be a tolal factor to the people I have talk to. Oh yes they know there are better product out there. But there response was it was easy I didn't have to do a lot to paint! The answer to the how good it was is it ok. I said how come you didn't go to a cheap paint shop well they though the work man ship was less that fair and felt they could do a better job for the money.
On a side not I notices the price has jumped up from 19.00 a Qt to 22.00 a Qt I assume its selling well!! based on the price jump. Its just a matter of time before someone else jump in to counter this with there own product!! Craig |
Different shops competed to see who could come up with the best Idea's with the paints!! Them guy did some super work with this paint. A very smart marketing move I believe. Craig |
I agree on your reason for using the product and when you have the cash for the bc/cc you can have it done Perfect! AZ is not up there with CA yet but if you paint and get turned in then your have the city to deal with. A factor that seems to escape this post you need a booth with Other paints Dup Lacquer you don't. Craig |
I totally agree. Those are some of the exact reason I choose to us it. I finally was able to use the dupli color on a headlight bucket and it turn out very good. I set up a home made spray booth to try and keep the dirt and dust off as I painted. I used a hvlp gun from harbor freight(1.4 tip) set at 30 lbs. Temp was about 70. I sprayed 3 light coats of the primer, then wet sand with 400 grit. I then sprayed 3 light coats of color and 5 light coats of clear and then color sanded again with 1500 and 2000 grit followed by buffing using a low speed buffer. I can not see how it could look any better. I did not have any flaws except some minor orange peel. Don |
Nice, I did about the samething with my test panel. It was about 110 out side and 70's in the garage. If you get a chance post some pic's.
Craig |
go to a tractor place that has tractors in a color you like. and buy the paint and hardener.. you will want a gallon of paint and a quart of hardner to do your car. should last a while if you take care of it.. but there are some economy acrylic enamel auto paints that are not much more than the tractor/ impliment paints, but there all mail order so you have some shipping costs ontop of that..
don't get the rustoleum 'specialty' enamel from the hardware store. it's just Rustoleum in the correct colors to match the tractors |
Specifics, please
The opinion of the body shop pro's about PAINT SHOP lacquer carries weight. But please, give us some specifics about why you reject the paint. It's not enough just to say..."lacquer sucks" or "we tried it and threw out the left over (Jeff)."
What EXACTLY is the problem with this paint? The application process? The finish? The consistency? The durability? Let us in on the secret, folks. Some detail (and hard evidence) would help alleviate the lingering doubt that the body shop pro's have a dog in the fight against the do-it-yourselfers. |
I am a DYI guy myself these days and as far as the Duplicolor for one it does not cover as well so I need to buy more paint than i would if I use a quality material so my expense is more..One of the hard lessons learned. another thing is the durablity as it is just as much work to do the prep work for dupli-color as it is to prep for quality material..another hard lesson learned..I have found that with careful shopping I can get the primer..the clear and the base for an all-over for about 450/550 plus sandpaper and masking and other sundries.. and it is just as much work to do the prep for good stuff as it is the other stuff and the most of the work is in the prep so why not use good pro quality material???
Sam
How can Duplicolor be easier than say ss/au?
Lacquer shows sanding scratches very easily,so you have to make sure your sanding is a good as if not better than if you were using ss au. Nothing easier there... Lacquer needs polishing, so to polish it you need a film thinkness adequate to polish as polishing removes paint. ss /au does not need polishing, but if you mess it up and it is a solid color then cut and buff works, just make sure you have adequate film Nothing easier there... Lacquer will require much maintainence. SS /AU will not require any maintainence Nothing easier there.... |
red , dont you find it strange that his first post is on an old thread long dead ?
Let's say I want to put 4 coats of primer on my ready-to-paint car (holes and dents filled, everything as straight as I can get it). My rule of thumb is that it takes one quart of sprayable paint per coat. Examples: 1. Summit Racing http://www.summitracing.com/checkout/cart.aspx $ 79.80 4 quarts Duplicolor lacquer primer @ $19.95 9.95 Ground shipping - 1 week? $ 89.75 2. Southern Polyurethanes Inc. (SPI) http://www.southernpolyurethanes.com/Pricing%20Info.htm $ 29.30 Quart of epoxy primer 29.30 Quart of activator 31.70 Gallon of reducer 0.00 2-day shipping $ 90.30 For 55-cents I receive two extra quarts of reducer for gun cleaning. Of course reducing SPI's epoxy primer 100% goes against all advice and is something I wouldn't do but I'm pretty sure it would have the same build and film thickness as the DupliColor lacquer primer. If you really believe 4 coats of thinned lacquer primer is as good as 2 coats of SPI epoxy you should go with the thinned lacquer and save the 55-cents (put it toward some lacquer thinner). |
bob , the guy is a troll out marketing duplicolor . either that or one of the same posters under another name. i'm still waiting to see one of these super wammy jobs done with it.
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Need advice on a paint job | tishmomo | Body - Exterior | 36 | 01-15-2008 11:19 AM |
| looking for a shop that shoots lacquer paint | domenicsantucci | Body - Exterior | 3 | 01-08-2003 02:51 PM |
| Looking for a good Paint and Body Shop in the OC Southern Cal Area | Mitch | Body - Exterior | 4 | 11-03-2002 06:26 PM |
| San Francisco Area Paint Shop | billcar670 | Body - Exterior | 3 | 10-24-2002 05:33 PM |
| san francisco area paint shop | bruce66 | Body - Exterior | 0 | 11-21-2001 07:43 AM |
