Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dupli Color Paint Shop auto paint Lacquer
  #170 (permalink)
Old 12-30-2009, 03:09 AM
ChevyTruckGuy ChevyTruckGuy is offline
Race The Truck
Last journal entry: Son's Truck
Originally Posted by brown37
Some of the other posts have said that lacquer is no safer than acrylics because of you get high off the fumes. Are you not using a mask? I hope no one on this thread is using any paint without protection. Lacquers are safer to use because the do not have ISO's in them. ALL PAINT IS BAD TO BREATH. I looked up the MSD for a bc/cc. and the manufacture said to use full hood with fresh air supply because of the ISO's.
Lacquer can be sprayed safely with a canister face mask(new canisters), protective clothing and ventilation wheres as bc/cc require a fresh air supply.
Am I wrong?
NO! your not wrong! Safer yes for sure! You posts made my point to the tee!
I agree on your reason for using the product and when you have the cash for the bc/cc you can have it done Perfect!
AZ is not up there with CA yet but if you paint and get turned in then your have the city to deal with. A factor that seems to escape this post you need a booth with Other paints Dup Lacquer you don't.
Craig
