Duplicolor primer and house of Kolor paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2005, 09:20 PM
Ok guys, I have done some research on this for 2 days now and came up empty handed. I just wrote tech support for house of kolor also.
This is my first time to shoot my own car. needless to say i am a little anxious. I have put around 3 months worth of work into my prep/ sanding ect.. ( my wife thinks i should just move out to the shop
So i went to Sherwin Williams and stated that since this is my 1st time to do my own paint that i would like to keep my budget small, in case i have to redo it. he reccomended that I use a Duplicolor Primer and sealer he had on the shelf. it went on well with my HVLP gun and looks good. I found the color base coat/clear coat that i would like to use and it is a HOK shimerin cinder red.
Do any of you know if this will react with the duplicolor primer in a negative way? If so can you guys reccomend a decent paint ie.. ppg,ect that will work over this primer. thx for your help later Aaron
i found this info on the subject @ stovebolt.com... it looks like martinsr is also a member over there http://www.stovebolt.com/bboard/cgi-...c;f=4;t=001398
Old 11-18-2005, 03:51 AM
adtkart@aol.com
If that is not the rattle can paint, I don't see where it should be a problem. Many people say to stick with same brand materials. I agree that the reducers and activators should be matched to the paints. I don't really see where the brand of primer being different than the paint should be a problem. Just make sure it isn't a lacquer primer. That won't work!
JMO
Aaron
How are you going to heat your house this winter? CrashFarmer2 Hotrodders' Lounge 29 09-05-2005 06:11 PM
Would anybody here by a house that.... onebadmerc Hotrodders' Lounge 36 03-23-2005 11:04 PM
just re-fied the house!!! bullheimer Hotrodders' Lounge 4 10-29-2003 06:54 AM
Garage Tools for The House Project?! Weimer Hotrodders' Lounge 13 01-07-2003 05:32 PM
Installing an inner wheel house carnutjoef Body - Exterior 2 01-08-2002 05:44 AM
