DuPoint Problem Plz Advise - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2004, 05:40 PM
Ok I used DuPoint Primer and its complete **** i dont really wanna remove it all off the entire car and go buy good quality primer so lets say i use the cheap dupoint bc/cc system would this look good for lets say a year? then i could repaint it and do it all right not to mention this would give me a good oportunity to practice the spraying myself? or how long would you figure the dupoint primer with the bc/cc dupoint system on top of it would last?
Old 06-20-2004, 05:58 PM
BarryK's Avatar
Yes and Yes.
With the primer you have on there now this is one time that using say a nason base, you would be further ahead than using the Dupont. Now don't get me wrong best deal is like I said before strip or put epoxy over it. If you chose to do neither than
use the Nason base for less melting of primer. This will increase the chances of Long term success.
Old 06-21-2004, 09:57 AM
Wiki Edits: 49
Re: DuPoint Problem Plz Advise
Which DuPont primer did you use, they only have a couple dozen.
Centerline
Old 06-21-2004, 08:02 PM
adtkart@aol.com
I have used Dupont products for years, and never had any problems with them. I would be interested in which product you are talking about. Most times I have heard of someone having a problem with it, there were reasons for it, like improper mixing, old, out dated products, improper use. What kind of problems are you having?
Old 06-21-2004, 10:37 PM
i made a new post fixing this i ment duplicolor no dupoint
Old 06-21-2004, 11:04 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
There's nothing wrong with dupont primer.
Never heard of duplicolor?
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
