Dupon epoxy,2K and top coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2004, 11:06 PM
Hi guys, I'm new to the forum and like to thank everyone who helps to the guys like me who is just learning. I have been reading the forum for a while and learned alot.
My 67 Camaro allmost to the bare metal now and I like to prime it with Dupont epoxy, 2580cr to be exact. But I have been reading Dupont sides about the compatible 2 K Urathane found nothing.
Am I missing something? I could not found anything that goes after epoxy.
Would you sugggest something in Dupont line that works with their epoxy.
Thanks
Old 12-22-2004, 05:39 AM
BarryK's Avatar
Once you spray the epoxy normal wait time for applying another product is 30 minutes to 2 hours depending on company.
(So if not sure let set over night to be safe)
After that point anything can be applied over the epoxy such as any 2K primer, any base-coat, any type of enamel, any lacquer,
any single stage paint, even clear.
Also what this means is the 2k primer could be BASF, PPG, Spies, S&W or Debeers and its all compatible.
The only thing I can think of that you cannot apply over the epoxy is an Acid etch type primer.
