dupont 3240s 2K primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2005, 01:37 PM
I'm going to shoot Dupont 3240s 2K primer and tip size suggested is 1.4 in the tech sheet.
I have read here that 2K primers in general requires 1.7 1.8 tip. Can I get away using my 1.4 tip on this primer? Any suggestions?
Thanks in advance for help.
Old 06-17-2005, 03:55 PM
If it says 1.4 in the tech sheets you KNOW it will work.
Old 06-17-2005, 11:42 PM
Thank you Brian. Allso I like to ask you this. As far as I know this is a low iso or none iso primer. Should I worry about quality or it is ok?
Thanks
Old 06-18-2005, 01:14 AM
Honestly, I don't know the product at all. But someone else will be posting to let you I would think.
Old 06-19-2005, 08:30 AM
PaintTech Instructor's Avatar
The Painter That Knows All !
yes your 1.4 is fine it still give 4 to 6 mils in 2 coats
Old 06-19-2005, 09:37 AM
The Paint tech instuctor (alleged "paint tech instructor") is right, it is right here in the tech sheet. http://www.performancecoatings.dupon...9031_3240S.pdf
However, also found there was the fact that it is a urethane and NOT "low or No ISO"! If you are using this product for that reason, you done got lied to.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Bare Metal Mollard Body - Exterior 71 09-25-2008 01:48 PM
Nason 2k primer oldred Body - Exterior 1 04-18-2005 09:15 PM
Lacquer primer question badriand Body - Exterior 18 07-23-2004 03:08 PM
2k Primer scraping off? Need help misteryu Body - Exterior 1 07-17-2004 04:55 AM
