DuPont Centari Ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2002, 04:09 PM
Post DuPont Centari Ratio
I need to know the mixing ratio of the above mentioned paint. Tower Paint says the ratio is 8:2:1. But the can says that it is 2:1. It mentions nothing about the hardener. What should I do?
Old 06-17-2002, 06:45 PM
4 Jaw Chuck's Avatar
Post
The amount of hardener to use is a range depending on your temperature, humidity, etc. Contact Dupont for the recommended ratio for your conditions on their website.
http://www1.dupont.com/NASApp/dupont...oductsMain.jsp
— Han Solo
Old 06-17-2002, 07:34 PM
Post
hey coodeville! the proper ratio for centari using hardener is 8 parts color, 2 parts reducer,1 part hardener. this is correct when using 793s hardener[which gives a great gloss /depth]the proper reducer to use will vary according to temperature [air] that the paint will be applied. right now im using 8022s which is good for 80 degrees and up for spot/partial repair and 75 degrees for overall paint jobs,although i have used the 8022s for overall at and above 80 degrees.as it warms up you have to use different reducers,your dupont paint shop will tell which reducer to use.hope this helps,see ya! jimm
Old 06-17-2002, 07:37 PM
Post
Boy did it help me! You guys are great! It's not easy findingthis stuff out on DuPont's site. You haveto go through all sorts of garbage to find out squat! Thanks!
Old 06-18-2002, 02:49 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Neat trick I have found using urethane hardner; I put it in all my model spray and brush paints and it is completely compatible and hardens them right up! Also, I use urethane thinner in the same paints which evaporates much better than the usual enamel paint thinner and doesn't hurt the plastics even though it smells like lacquer thinner (of course test all this first on scrap plastic to see if yours is different!).
[ June 18, 2002: Message edited by: willys36@aol.com ]</p>
Dynamic Compression Ratio?? starnest Engine 3 04-27-2007 02:22 PM
ppg deltron or dupont centari 600/6000s? 73rustbucket Body - Exterior 5 11-05-2006 01:49 PM
Dodge overdrives allstar mike Transmission - Rearend 3 05-30-2006 10:37 PM
Clutch pedal ratio? Super Chevy General Rodding Tech 5 04-13-2006 02:55 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
